Major disappointment
D. Sea
6jeff6
Page 1 of 3
Page 1 of 3 • 1, 2, 3
Well the cobra did not perform well at all. Best time 12.032 @ 113.40 with 1.749 60 ft. It breaks up at 5,550 so I couldn't go to planned 6 grand to shift. I'm rained out today so I'll pull plugs but any ideas? I'm leaving at about 3,500 give or take a few rpm. I expected way more out of the 521
6jeff6- Posts : 279
Re: Major disappointment
There are always bugs to work out. I picked up 8 tenths when I figured out my throttle wasn't opening all the way.
You definitely need to figure out that miss. Could be as simple as fouled plugs, depending on what you're running. Do you have an AF meter?
cletus66- Posts : 865
That's good to hear. Now I loosen the front band a little for more grab right? Just felt a little loose and pulled hard once going but I expected more of a shock with 3,500 stall.
Wish I could afford to get nos going as I think it's actually all set up to spray and why there is issues n/a but baby steps.
My biggest disappointment was mph that's low
6jeff6- Posts : 279
Details would help.
D. Sea- Posts : 2768
Car 97 cobra nice set up built 8.8 with spool will check gears today but when bought car said 3.73s or less, spool, 28x10x15 slicks, aluminum drive shaft, built c4 with 3,500 stall, bone stock 521 from roush/Yates with kooks headers that made 609 hp at 5750rpm with 1050 dominator carb.
6jeff6- Posts : 279
10 gallon fuel cell in trunk with battery in trunk also. Full interior with welded roll bar. Full length race sub frames with axle girdle (I can't remember what it's called).
Ran almost straight turbo blue
6jeff6- Posts : 279
Well may have found the issue there's a 2 step somewhere on the car and maybe they have Rev limit too low. Any hints on the 2 step? Peak torque is 4,500 with peak hp at 5,750.
6jeff6- Posts : 279
2 step:
Start is at 10
Step retard little arrow is pointed at E 14.
This is PN 8987
Start is at 10
This is PN 8987
6jeff6- Posts : 279
Plug is really black. Maybe too much street idling ?
6jeff6- Posts : 279
Sounds really rich OR you're driving down the track on the 2 step? Should be a few seconds quicker with that kind of power. In the 6's 1/8 and 10's 1/4 for sure IMO.
I really don't know. How can I figure it out? I'm new to the 2 step
6jeff6- Posts : 279
I never hit the over rev/rev reduction peak at the line it was just quick rev to 3500ish and gone. So to test this just fire up car, put in 1st, hold trans brake, rev up and there should be a cut out/limiter and that's my first step?
6jeff6- Posts : 279
The #8987 is not a 2-step it is a start retard / activation retard the way you have explained it the box is retarding the timing 10^ on start-up, the E14 setting would be retarding the timing 14^ on activation (14^ retard from total timing) Follow the pink wire from the 8987 box and see where it goes this wire should only be activated for a given amount of nitrous, if it is activating now you are removing 14^ of total timing.
FalconEh- Posts : 1448
Pink wire goes by shifter into plug in, from there 2 go to button for reverse/trans brake, other two go back toward nitrous bottle in trunk
6jeff6- Posts : 279
Sorry they go to trans brake/reverse button
6jeff6- Posts : 279
And the other 2 go to nitrous button
6jeff6- Posts : 279
It sounds like they have wired the retard box to activate on the release of the trans-brake put a timing light on the car and rev it until the total advance is in likely you will not have enough advance, if this is the case turn the knob to 0 and try it again the total timing should increase by 14^
K I will have to wait until my son is home but if what you saying is right then if I fill bottle she's completely set up for the 125 shot?
6jeff6- Posts : 279
6jeff6 wrote:K I will have to wait until my son is home but if what you saying is right then if I fill bottle she's completely set up for the 125 shot?
That would depend on other factors too, it would mean that the timing retard is set to activate on the release of the t-brake button with the number of degrees you set the dial to. As for the 125 shot that would depend on the jets that are in the kit, whether the full throttle activation switch is hooked up, etc. but yes the timing retard would be ready for nitrous use.
From what the Jets are it's a 125 wet nos kit
6jeff6- Posts : 279
Now I have to depress and let go of trans brake when I do this to activate it right?
6jeff6- Posts : 279
I would not start spraying it until you get everything lined out. You do not need to pull 14 degrees of timing out for a 125HP shot either. Good idea to have a timing light to check the electronics also.
supervel45- Posts : 4499
http://www.jegs.com/InstallationInstructions/100/121/121-8987.pdf Here are the instructions for the MSD 8987 retard box.
6jeff6 wrote:Now I have to depress and let go of trans brake when I do this to activate it right?
No, just find the full throttle activation switch and close the loop (depress the switch arm with a zip tie or tape), the way it is likely wired is the nitrous will come on under full throttle by way of the full throttle activation switch, and the trans-brake will interrupt the nitrous under full throttle until the button is released.
» Ford Motorsport A460 Heads Reworked with a major issue
» major oil consumption
» Last major pieces of the puzzle are here...Thanks Blake!
» Major milestone at work today
» SGMP in Adel Ga. suffered major damage in tornado this morning
Page 1 of 3
