rocker arm stud to short. total length 2.5 in, iron cj harlem sharp rockers
What rocker arm stud should I use? Total length of current stud is 2.5 in. Iron CJ heads, Harlem Sharp rockers. Please help. Thanks for your time. B-351 coloil@yahoo.com
B-351- Posts : 8
Re: rocker arm stud to short. total length 2.5 in, iron cj harlem sharp rockers
B-351 wrote:What rocker arm stud should I use? Total length of current stud is 2.5 in. Iron CJ heads, Harlem Sharp rockers. Please help. Thanks for your time. B-351 coloil@yahoo.com
With a standard Harland Sharp rocker arm the top section of the stud should be 1.84" or longer. If that seems to be to short with that rocker arm, then the pushrod is probably a bit to long.
The standard Harland Sharp rocker arm sits farther down on the stud than most other rockers in the marketplace.
» New Harland Sharp S4005 - Harland Sharp Roller Rockers
» Converting SBF pedestal mount heads to adjustable rockers... Which length rockers to use???
» Harland sharp rockers
» Harland Sharp 1.70 Roller Rockers
» M-6345-A Stud length concern
