94 f150 suspension and bushings.
I am about to take apart the front suspension and replace all the bushing with "energy suspension" bushings. (Everything) I want to replace the radius arm bushings with hemi joints. Will the "lifted" radius arms work on factory ride height?
Would it benefit the truck if I had all of the major bushings made from aluminum or self lubricating copper?
jones- Posts : 2230
Re: 94 f150 suspension and bushings.
I found a couple of businesses that make radius arms that have hemi joints that replace the bushings. The parts are made for off road trucks but I think there might be some stuff I can use that would help eliminate suspension slop.
I'm just going to use long bars in the rear, remove a couple of leaves from the leaf package and run adjustable shocks.
jones- Posts : 2230
These are 10" longer than factory, hemi rod ends and the manufacturer says they will work at factory ride height.
jones- Posts : 2230
» 79 ford f150 suspension
» Strut Rod Bushings
» Which bushings for k member?
» Lifter bushings
» MSD 8580 Distributor Adv Bushings
» Lifter bushings
