K Memebr Mix and Match!!
K Memebr Mix and Match!! Empty K Memebr Mix and Match!!
Post  billandlori November 6th 2015, 6:42 pm
Hey guys,
I am getting my Fairmont pieced together. I am using the drivetrain out of my 1983 T-Bird.
The Fairmont was an I6 car. I have read that the T-Bird control arms are longer, I would like to use the T-Bird K Member cause it has the cut outs to save weight but I don't want a ton of camber!! Would I be able to use the Mont control arms with the T-Bird K Member?
Thanks for the thoughts,
Bill
K Memebr Mix and Match!! Empty Re: K Memebr Mix and Match!!
Post  Mike R November 6th 2015, 7:58 pm
I'm pretty sure the T-bird k member won't fit. I believe the rear mounts are in the wrong spot
Post  billandlori November 7th 2015, 1:40 am
Mike R wrote:I'm pretty sure the T-bird k member won't fit. I believe the rear mounts are in the wrong spot
Thanks Mike!!
Might be time for a tubular K Member lol!!
Bill
Post  Mark Miller November 8th 2015, 2:24 am
billandlori wrote:Hey guys,
Bill
When i had my 88 T-Bird i used a 5.0 Mustang K-Member so i could use the 460 Swap Motor Mounts.When i did that i had to end up using the Mustang lower control arms because the T-Bird lower control arms were longer.Don't know if this helps or not figured i would put my 2 cents in!!!!Laughing Laughing Laughing
Post  billandlori November 8th 2015, 9:38 am
Bill
Thanks Mark!!
I'm just going to run the heavy stocker for now and swap in a tubular when I can afford it!!
It is an I6 K Member so I'm going to have to drill engine mount holes, that will let me put the engine back a bit more.
Bill
Post  jbozzelle November 16th 2015, 12:07 pm
I thought the I6 frame stands were too tall for a V8?
Post  billandlori November 16th 2015, 6:27 pm
I heard they were different too John. I have to do some more measuring but they look like the right height, just the motor mount bolt is too far forward. That might work out ok, cause then I can drill the hole where I want and get the engine back a bit further. I might just cut the buggers off and use motor plates lol!!!
Bill
Post  billandlori November 20th 2015, 11:48 pm
Yep, your right John, the heights of the engine mount tabs are higher. So....I guess its out with the grinder!!
Bill
