short oil filter
crittersf1
manofmerc
Larry Williams
short oil filter
is there a super short oil filter that fits a 545?
header interferance is a problem
Larry Williams- Posts : 884
chrysler
Check what a small block mopar uses .I am confident they are the same as the ford but shorter .
manofmerc- BBF CONTRIBUTOR
Re: short oil filter
FL-300 = short mopar filter.
http://www.jegs.com/i/Motorcraft/037/FL300/10002/-1?CAWELAID=1798934895&CAGPSPN=pla&catargetid=230006180000848673&cadevice=c&gclid=CP_XzpLugckCFQOUaQodpRYFUw
Larry Williams wrote:is there a super short oil filter that fits a 545?
There is a filter which is only about 2 1/2" tall but, I can't remember the application it is originally for.
....or use the Ford Racing adaptor. It allows you to clock your filter in any direction.
maverick- BBF CONTRIBUTOR
I have the ford adapter and it hits the motor plate. The remote adapter I don't trust after my other car developed leaks. I would prefer Randy's solution if I could get a part number
I know that it probably sounds "oddball", but I used a NAPA filter for a Renault Lecar (spelling?) with good results. Used on a 351 Cleveland in a Model A chassis, needed a super short filter to clear the steering shaft, it worked perfectly - sorry, I don't have a number for it. Maybe NAPA still has a listing.
Wayne (SAWDOFF) Pearce
Wayne Pearce- Posts : 658
Napa 1335 super short filter
Attributes
Filter O.D. (Inches) : 3.67"
Height (Inches) : 2.483"
Thread Size (Inches) : 3/4-16
Beta Ratio : 2/20=6/20
Burst Pressure : 280 psi
Filter O.D. (mm) : 93 mm
Flow Rate : 7 - 9 gpm
Gasket I.D. (Inches) : 2.462"
Gasket I.D. (mm) : 63 mm
Gasket O.D. (Inches) : 2.834"
Gasket O.D. (mm) : 72 mm
Height (mm) : 63 mm
Media Type : Glass Enhanced Cellulose
Micron Rating : 21 Micron
Style : Spin-on Oil Filter
napa 1515 specs standard ford filter
Attributes
Filter O.D. (Inches) : 3.66"
Height (Inches) : 5.178"
Burst Pressure : 290 psi
Gasket I.D. (mm) : 62 mm
Height (mm) : 131 mm
Attributes
Height (mm) : 63 mm
Attributes
Last edited by strokedmyford on November 14th 2015, 10:16 am; edited 1 time in total
strokedmyford- Posts : 126
the FL300 suggested by Lem has solved my problem. Thanks for all the replies
Larry Williams wrote:the FL300 suggested by Lem has solved my problem. Thanks for all the replies
So, you didn't need the SUPER short filter after all.
It's good that you got your problem solved. Now others also know that a SUPER short one does exist.
460bronc likes this post
The jomar filter is 5 1/4 tall the FL300 is 3 1/2 with the ford adapter i get the clearance I need from the motor plate. A filter @ 2 1/2 inches would let me omit the ford adapter but Napa wasn't a lot of help finding the really short one.
» Short Oil Filter
» Short Track (REALLY SHORT) Racing this past weekend
» K&N air filter top
» the short bus
» Lifters and Oil Pressure
» the short bus
