rear sump oil pan
rear sump oil pan Empty rear sump oil pan
Post  Bart Knox November 11th 2015, 6:53 pm
How much can I drop my motor swaping oil pan for a rear sump? Trying to save money not getting hi angle drive shafts so I can put more money into my motor. Thot $200 would be better than thousands
Bart Knox
Bart Knox
http://W. B Knox&son LTD Huntsville Ontario
rear sump oil pan Empty Re: rear sump oil pan
Post  Bart Knox November 14th 2015, 9:17 am
Can you just flip the pan end for end? I know that the Cummins in the skidder I was working on last winter buddy bot a used motor and pretty sure that we tured the pan they other way
Bart Knox
Bart Knox
Post  69F100 November 14th 2015, 9:49 am
Bart Knox wrote:Can you just flip the pan end for end? I know that the Cummins in the skidder I was working on last winter buddy bot a used motor and pretty sure that we tured the pan they other way
No the pan goes on one way only. Have you looked at the mustang swap pan.
Post  Bart Knox November 14th 2015, 12:05 pm
I was outside looking at it and it looks like it might be a bit of fabrication.I had to put in a body lift so I could shut the hood with the air filter but can't rilly see how it could be dropped. I fabed the motor mounts just welded ears on the stock mounts might be stuck with it ware it is.
Bart Knox
Bart Knox
Post  Bart Knox January 7th 2016, 6:28 pm
I no this is a old thread but im in search of what oil pan I should get to drop motor 4 inches ruffly... Right now I have the front sump pan that was on the motor when I got it and fabed my own mounts... The oil filter sits above the hole in frame... Can't deside weather I should get a pan from a 80s or 90s 460 and a set of swap mounts? The Bronco is a 95 or if I can get a couple more inches if I get a rear sump pan and cut the towers on the frame down a bit? Thanks
Bart Knox
Bart Knox
Post  Bart Knox January 7th 2016, 7:54 pm
And would I need a different oil pump or just a pick up
Bart Knox
Bart Knox
