rear sump oil pan
snuff98
gt350hr
norm
mitch huested
rear sump oil pan
Hey everybody, I'm looking for someone who knows of a rear sump oil pan for F-100 and F-250 two-wheel-drive truck in the '73-'79 years. No one seems to be able to give me a "for certain" answer. The Canton 15-774 looks like it will work, but Summit says it won't while Jeg's says it will! So now i'm here asking the experts. Thanks in advance for any help you all can provide,
mitch huested- Posts : 19
Re: rear sump oil pan
What about the Ford Racing 397-M-6675-A460 Rear Sump Oil Pan for the Fox Body 429-460 Swap will that work IIRC it's a Truck Oil Pan but don't remember what year trucks!!
Mark Miller- Posts : 1954
I don't have a 2wd so i'll ask what is under the engine? A crossmember or something that would be in the way of the sump on the pan in the rear?
4wd's have quite a bit of room and even moreso when lifted.
norm- Posts : 260
I have a '74 and a '78 F350 and both have 460s and both have front sum pans. There is plenty of clearance for a stock depth pan. A rear sump pan "might" run into the back of the cross member. The '74 pan has a longer sump and holds more oil. The sump length is similar to a Boss 429 but there isn't a baffle in it.
gt350hr- Posts : 662
Its the steering! Those trucks steer from behind the axle putting all the stuff where the pan should be. 4x4 half ton trucks steer from in front of the axle.
snuff98- Posts : 245
Those trucks in 2wd use a front sump pan that sits right over the cross member as the steering linkage is behind the wheels. In 1980 they switched it up and those trucks use dual sump or mid sump pans.
jasonf- BBF CONTRIBUTOR
My 75 2wd came with front sump also.
stanger68- Posts : 500
Thanks for the interest friends! My main reason for wanting a rear sump pan is due to the engine and the expected launch of this truck. I know it weighs a lot, but my engine will move it out anyway. It's a 557cid, 10.2:1 compression, monster on nitrous. Block is "cemented" halfway up the jackets, with 249/254 @.050 cam, Aluminum heads ported and polished. Lunati forged 4340 crank and rods with ATI dampener and SFI flexplate in front of a Hughes C6 with trans brake. Nitrous kit is dual stage 250/400 shot.
BUT my other main reason for a rear sump pan is the MESS that inevitably happens when changing the oil using the front sump pans, as they always drain right onto the crossmember! I've owned 2 trucks in the 73-79 range and they always make a huge mess changing the oil. Those of you who have the front sump pans know what I mean. Currently i have a 7 quart front sump pan that is stock for "trailer specials", and yes still messy.
Weld a horizontal slosh baffle across the rear half of the front sump.mitch huested wrote:...My main reason for wanting a rear sump pan is due to the engine and the expected launch of this truck.
Relocate the drain plug to either side of the rear corner of the sump (do this before welding in the slosh baffle)mitch huested wrote:....my other main reason for a rear sump pan is the MESS that inevitably happens when changing the oil using the front sump pans, as they always drain right onto the crossmember!
If you still want a 1979-up F250 pan & pickup I have plenty of them.
norm wrote:Why such a small cam?
Not everyone’s a HeRo......
Hey Norm, the lift is .637 on the cam, but wanted to keep the duration down a bit so I would be able to hit the main powerband(2400-6600 advertised) quick enough to not bog off the line. Also, this is @ .050, the advertised lift is 292/300. Launch will be at 3200rpm with a shift somewhere around 6500(twin 200lb. weight bars in back). Nitrous kicks in at 3500.
Just seems with 557 cubes you could have gone bigger and still be able to get off the line.
I would think that would be a small cam for a 460 personally.
Heroes notwithstanding.
norm- Posts : 260
» Front sump vs rear sump
» rear sump oil pan
» Rear sump oil pan
» Rear Sump oil pan question
» wtb rear sump bbf pan
» rear sump oil pan
» Rear sump oil pan
