Help with spec'ing out some new pistons and best (max cam) for stock D3VE's
Help with spec'ing out some new pistons and best (max cam) for stock D3VE's Empty Help with spec'ing out some new pistons and best (max cam) for stock D3VE's
Post  skosler November 27th 2015, 5:22 pm
Dusted off the 466 that was siting in the shop for 5-6 years.
So, it's been awhile since I messed with my old BBF, but I bought another project truck and want to freshen her up and drop her in the new project truck. I built the engine about 6-7 years ago and she ran ok, but then I pulled her and she sat in the shop for the last 5+ years. Mud daubers and even a mouse made home inside (I had the intake pulled and the cover came off, at some point).
I got her up on the engine stand and broke her down and found one cylinder that had slight pitting and one KB hyper piston that had the skirt cracked.
I found my old posts and this was the data I had 6+ years ago. With this build I was hoping to have 375-400 hp.
Since I have pitting I am going to clean that up and will probably end up going from 30 over to 60 over. I estimate my old static compression ratio to be about 9.1-9.2:1.
Based on the specs below, which piston could I go with, that would work with my zero decked block and milled heads and give me better compression ratio? I’m hoping to get her up to about 9.5-9.6+
Also, what’s that tallest/best cam that I can go with, with stock valve train?
In short,
D1VE block decked .020, balanced, bored .030, stock stroke
KB hypereurtectic (sp?) -15cc pistons. Stick out of block about .002
D3VE heads decked .020, 3 angle valve job on stock valves, intake ports smoothed out, exh ported (by me), .039 thickness head gasket for about .037 quench clearance, stock rockers
~9.15:1 comp ratio
Performer RPM intake
SUM-3501 cam Advertised Duration 276/ 286, Lift .503/ .503 (good for stock valvetrain)
holley 750 dp carb
cheap hedman headers
2.5" exh with "wide open" mufflers
straight up timing set
recurved dizzy
skosler
skosler
