Cam questions
Cam questions
I'm running a comp xr292r cam I'm looking into changing the street grind solid to a race grind solid...
Combo is a 10.8 static with scj-b heads vic intake and 1050dom
This is the cam I'm looking into...
Big Block Ford 429-460 Solid Roller Cam - 266°/274° @.050 .709 lift
Fits Ford 429-460 cid engines
Grind - R-292-1A
E260903
RPM Range 4200-7500
Duration @.050 Lift 266/274 deg int/exh
Valve Lift .709 int/exh
Lobe Separation 108 deg
Advance 0 deg
Advertised duration 292/300 deg int/exh
Lift based on stock 1.73-1 rocker ratio
Valve lash .026 in
Grind - R-292-1A
E260903
RPM Range 4200-7500
Advance 0 deg
Valve lash .026 in
gmsmkr- Posts : 1364
Re: Cam questions
472 ci c6 trans running a 4.10 gear and a 29/10.5 tire
Re: Cam questions
Only street use is short runs to eat lunch and local track T&T..... about 40 miles on a weekend and weekday for a hamburger
Re: Cam questions
gmsmkr wrote:Only street use is short runs to eat lunch and local track T&T..... about 40 miles on a weekend and weekday for a hamburger
What converter,how much juice, and what hamburger
FalconEh- Posts : 1448
Re: Cam questions
Converter will be 4500, nitrous just enough to win and the hamburger is the choke and puke just down the road..
Rusty, how is hunting season going??
Re: Cam questions
Over for deer, meat hanging and the first batch of deer jerky turned out great. might need to leave in second when lined up beside the 5.0 that 4500 brings the heat.
Re: Cam questions
gmsmkr wrote:Converter will be 4500, nitrous just enough to win and the hamburger is the choke and puke just down the road..
Is the burger any good?
Re: Cam questions
dfree383 wrote:gmsmkr wrote:Converter will be 4500, nitrous just enough to win and the hamburger is the choke and puke just down the road..
I think that burger is the only one for miles, so.......yes.
maverick- BBF CONTRIBUTOR
Re: Cam questions
Yea it's a good place to eat....
» C6 questions
» Jon Kaase SR71 Cylinder Heads
» 429 QUESTIONS
» Questions on an '85 460
» 572 to 598 questions
» 429 QUESTIONS
