Electric fuel pump for street use
yellowhorse7
JBR-3
Last edited by JBR-3 on February 22nd 2020, 2:28 am; edited 2 times in total (Reason for editing : .)
JBR-3- Posts : 266
Re: Electric fuel pump for street use
Magnafuel or Walbro. End of discussion
yellowhorse7- Posts : 1382
A1000 pump 10AN feed to Reg from there its 8AN to carb and 8AN back to cell pressure set at 5.5psi.... on big block car.
Small block car is the same other than feed and return lines.
Never had a problem with aeromotive stuff
gmsmkr- Posts : 1364
no pump advice but my experience with 3/8s lines tell me to just run the braided shit and be done. I spent hours and multiple lines trying to make the lines look like they belonged on the car. waste of time and money. it wound up costing the same as the braided line stuff. the new push lock stuff is even cheaper besides. bobn
zbob- Posts : 271
The Aeromotive stuff is usually fine for a lot of street/street-strip/bracket/hot rod/street rod/a little nitrous/etc stuff. But when/if things get big-time serious in the future then step up to a MagnaFuel pump.
If you're upgrading the pump you might as well step up to a 1/2 main feed line over the 3/8 stuff. Especially if the fuel cell/tank is staying in the back of the car.
DILLIGASDAVE- Posts : 2262
gmsmkr wrote:A1000 pump 10AN feed to Reg from there its 8AN to carb and 8AN back to cell pressure set at 5.5psi.... on big block car.
I run this on a '68 coupe with a big inch small block and it's been great. While the car isn't a daily it sees plenty of street cruising miles. It's loud but has been flawless
Last edited by JBR-3 on February 22nd 2020, 2:29 am; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
DILLIGASDAVE wrote:The Aeromotive stuff is usually fine for a lot of street/street-strip/bracket/hot rod/street rod/a little nitrous/etc stuff. But when/if things get big-time serious in the future then step up to a MagnaFuel pump.
We use aeromotive stuff for almost everything. Up to blown alcohol pro mods with their new billet pumps. I would use an aeromotive pump over magnafuel any day of the week.
whatbumper- Posts : 3024
» Do I need to remove my already intalled fuel pump eccentric if I'm now going to be using an electric fuel pump?
» Running hot with electric pump on street
» What Electric Fuel Pump ?
» FMR 140 GPH Electric Fuel Pump
» Electric fuel pump
