Moroso Racing Vacuum Pump #22641 4 vane with 2 pulleys... Fittings as well
Used 1 season
Original Racing Vacuum Pump
4-vane pump
Billet aluminum housing
Pulls much more vacuum than stock smog pumps
Special vane material for improved seal and wear
-12AN inlet/outlet fittings won't leak
Rebuildable in 15 minutes
Mounting bracket sold separately (bolts directly to small or big block Chevy heads & any motor plate)
$350 Shipped...
Mike Konigshofer
(519)860-2565
mike@speednorth.com
Used 1 season
4-vane pump
$350 Shipped...
Mike Konigshofer
(519)860-2565
mike@speednorth.com
mike konigshofer- Posts : 9
Re: Moroso Racing Vacuum Pump #22641 4 vane with 2 pulleys... Fittings as well
Welcome to the Auction Block
the Coug- Posts : 3055
Randy, you still have Chilly on your mind? This is Stuff for sale!the Coug wrote:Welcome to the Auction Block
chuck- Posts : 414
SOLD....................
Thanks guys....
Thanks guys....
» Moroso 22642 4 vane vacuum pump SOLD
» aerospace 3 vane vacuum pump... anybody run one? good piece or not so much?
» Vacuum Pump Pulleys
» Timing Cover Vacuum pump fittings New $$$$
» if you were going to use a vacuum pump would it be moroso or aerospace?
