Vacuum Pump Pulleys
Vacuum Pump Pulleys Empty Vacuum Pump Pulleys
Post  Tore July 14th 2016, 12:19 pm
I am considering putting a vacuum pump on my engine in a bit. I was wondering can you run these off the factory stock Ford pulley on the crank or do you have to bolt some kind of adapter to your existing pulley?
Thanks Tore
Tore
Tore
Vacuum Pump Pulleys Empty Re: Vacuum Pump Pulleys
Post  cool40 July 14th 2016, 1:18 pm
Stock pulleys would be hard to deal with for your ratio.I suppose it could work with a very big pulley on the pump. scratch
Post  bbf-falcon July 14th 2016, 7:56 pm
Tore,i might have a small pulley.Maybe for some eggs.
Post  Tore July 14th 2016, 9:19 pm
bbf-falcon wrote:Tore,i might have a small pulley.Maybe for some eggs.
LOL Bkfst was good. Very Happy
Tore
Tore
Post  wayney July 14th 2016, 10:22 pm
tore,
what happened in columbus? i was going to stop by after true street and you were gone?
wayne
wayney
Post  Tore July 15th 2016, 7:25 am
wayney wrote:tore,
wayne
The drain plug in the block started spraying water and I didn't have an extra.  I got home and there were 3 little pin holes in it. So I pulled the otherside also and that one was corroded real bad. Replaced them and all good to go for tonight!. Haven't seen you for awhile. would have been nice to talk.
Tore
Tore
Tore
