Vacuum Pump
TRUKPULR
Vacuum Pump Empty Vacuum Pump
Post  John Myrick February 16th 2012, 6:48 am
At what horsepower/ torque level is it wise to install a vacuum pump system ? This is for a wet sump deal.
Thanks in advance
Vacuum Pump Empty Re: Vacuum Pump
Post  TRUKPULR February 16th 2012, 9:28 am
Best way I can describe it is, if your motor leaks oil all over the place after you put a spanking to it you need a Vacume pump.
Dan
TRUKPULR
TRUKPULR
http://www.shazampulling.com
Post  dfree383 February 16th 2012, 9:47 am
IMO depends on the ring pack your using.
Post  cool40 February 16th 2012, 11:44 pm
if your gona run alky GET ONE!
Post  bbf-falcon February 16th 2012, 11:46 pm
From what i've read,a pump is a good thing whether you actually need it or not.
Post  rmcomprandy February 17th 2012, 12:40 am
bbf-falcon wrote:From what i've read,a pump is a good thing whether you actually need it or not.
When you don't actually NEED it, is when it works the best; unless your need is because you have specifically built the engine with the lowest tension rings and planned to use one all along.
Post  BOSS 429 February 17th 2012, 1:09 am
John Myrick wrote:At what horsepower/ torque level is it wise to install a vacuum pump system ? This is for a wet sump deal.
Thanks in advance
ANY engine can be helped by a vac pump,p it promotes ring seal, thus = more power
Post  LivermoreDave February 17th 2012, 8:16 am
Randy says it best! It reminds me of planting a shrub in the middle of the yard after the original landscaping is done. Did I plant that shrub because it's "the thing", because everyone else has one, or does it make the girls at the office go "wow", or did I not think out my landscape project? It's nice to look at a landscape that has been planned properly instead a landscape that has shrubs, trees and bushes growing at random because a bird shit a seed here or there!
Just more of my B.S.,
Dave.
LivermoreDave
Post  TRUKPULR February 17th 2012, 6:36 pm
n/m
TRUKPULR
TRUKPULR
