Which vacuum pump?
BBF552
Which vacuum pump?
Any recommendations for brand of vacuum pump to use with a 632" C head engine? Been reading a few things about moroso 3 vane pumps and some say they don't pull enough vacuum for big cubic inch engines at wide open throttle and others say they work fine. Also read that Star pumps are the way to go. Trying to see what everyone else has experienced before making a purchase.
BBF552- Posts : 34
Re: Which vacuum pump?
Got a Star pump on mine
BBF552 wrote:Any recommendations for brand of vacuum pump to use with a 632" C head engine? Been reading a few things about moroso 3 vane pumps and some say they don't pull enough vacuum for big cubic inch engines at wide open throttle and others say they work fine. Also read that Star pumps are the way to go. Trying to see what everyone else has experienced before making a purchase.
I use the pumps from "GZ Motorsports" on the engines I build with crankcase vacuum pumps. Great results.
If you were to use the moroso go with the 4 vane pump which is designed for drysump engines. You can always bleed off or limit the vacuum with a blow off valve. What I did and worked great for what it's worth.
TravisRice- BBF CONTRIBUTOR
I ran across this unit Saturday afternoon. It's on a very large C460 unit that will have more than one 'kit'. External wet sump program.
Lem Evans wrote:I ran across this unit Saturday afternoon. It's on a very large C460 unit that will have more than one 'kit'. External wet sump program.
Young kids have nothing on you. Nice selfie....lol
Whoooooooooo shiney
That's not the portrait series Lem Evans water pump is it.? Lol
moroso 4 vane,and you can always back it off
BOSS 429- Posts : 2372
» which vacuum pump?
» vacuum pump ?
» vacuum pump!
» when do you use a vacuum pump?
» vacuum pump ?
» vacuum pump!
