Cost offset grinding vs buying aftermarket
BigDave65
SandHillsHillbilly
What are the cost of offset grinding stock crank vs buying a cast stroker?
Re: Cost offset grinding vs buying aftermarket
SandHillsHillbilly wrote:What are the cost of offset grinding stock crank vs buying a cast stroker?
Call ADNEY at Performance Crankshaft and get some exact cost numbers. (586) 549-7557
The last ones I had reground were $350.
BigDave65- Posts : 567
Depends on if it is an odd stroke that nobody makes, for example 3.95 stroke.
Buying a new crank the stroke that you need will make it easier to resell when that time comes too.
10.0- Posts : 54
Adney is an awesome crank grinder.
Here's a couple already done. They've been for sale for a good while, maybe he'll deal http://minneapolis.craigslist.org/dak/pts/5346523424.html
Mike R- Posts : 1381
Not just offset stroked but equally indexed and gassed as well. For $325 I'd take OEM crankshafts like that over Scat 4.14s all day long.Mike R wrote:Here's a couple already done. They've been for sale for a good while, maybe he'll deal http://minneapolis.craigslist.org/dak/pts/5346523424.html
» Cheap 460 thrasher build plan for bracket tbird
» Stroke from offset grinding 429 crank?
» Thinking about offset grinding my crank, want info plz
» Destroke Offset grinding a Lunati 4.150 Fordged crank possible?
» aftermarket ford superduty rims, what offset/backspace do i need?
