Stroke from offset grinding 429 crank?
What is max stroke from offset grinding 429 crank with 2.20 rod?
Green 72- Posts : 41
Re: Stroke from offset grinding 429 crank?
What journal size?
About 4" of i remember right
4.60 stuff will go about 4.15
Green 72 wrote:What is max stroke from offset grinding 429 crank with 2.20 rod?
3.890" if it is to STANDARD size 2.200".
Thanks I knew the 460 was4.14 or 4.15 but did not know about the 429. Thank again.
3.89" on paper, about 3.885" under real-world optimum conditions, more if you're willing to go undersize (0.010" under, 0.020" under, etc).Green 72 wrote:What is max stroke from offset grinding 429 crank with 2.20 rod?
Edit: Ooops I guess I should have scrolled down and looked at the answers before posting, haha.
» Thinking about offset grinding my crank, want info plz
» Destroke Offset grinding a Lunati 4.150 Fordged crank possible?
» Cheap 460 thrasher build plan for bracket tbird
» Cost offset grinding vs buying aftermarket
» WTT hawks/RPM 4.5 stroke cast crank for 4.150/514 crank
