c460 cam.
c460 cam.
what springs would i need with the c460 hydraulic flat tappet cam? thanks jim
new2460- Posts : 195
Re: c460 cam.
The Doscontinued Ford Racing Springs A351 is what was used on the crate motors.
But you could use a Comp 924-16 or 930-16
Re: c460 cam.
Whatever springs will get you 125 pounds on the seat and about 320 pounds at .500" lift.
That Ford Racing spring is available from a lot of vendors using their part number and is the same as a #99893 Crane.
Re: c460 cam.
1.9 - 1.95 range with the Comp 930s
jbozzelle- Posts : 3705
» New C460 Intake Manifold M-9424-C460
» c460 pistons
» C460 heads on a 466......
» Timing For C460 604 CID
» C460 heads
» c460 pistons
» C460 heads
