Is a Victor and an 870 carb to much for my combo?
Is a Victor and an 870 carb to much for my combo? Empty Is a Victor and an 870 carb to much for my combo?
Post  paperman January 17th 2016, 9:49 pm
30 over, L2404 pistons, stock truck rods and crank with all ARP bolts through-out engine.  FMS A429 heads with slight port work, Harland BBF rockers, FMS C460 hydro flat tappet cam (.588-.614/244-254).  Mad dog 2-1/8 fenderwell headers to 4" bullets and about 3' of 4" pipe.   Engine in 95' 1 ton regular cab.  42" rubber, locked with 5.13's.  This engine is a stepping stone to a new build in the works and is being tossed together from parts laying on the shelf.  Some parts are new, some are old but all are in serviceable condition. I have the untouched Victor and a new 870 vacuum secondary carb to use if they are not totally wrong for the set-up.  Will this thing swing those Swampers or does it sound like a total abortion.
paperman
Is a Victor and an 870 carb to much for my combo? Empty Re: Is a Victor and an 870 carb to much for my combo?
Post  dfree383 January 17th 2016, 9:52 pm
Is do a smaller cam and use a performer RPM
Headers are a little large for the combo, but if your going big later it's a compromise.
Post  paperman January 17th 2016, 9:59 pm
Damn, I kinda was thinking the same thing:( , just wanted the brain trust to tell me. Next is a 4.5" deal so the headers we picked up for that in mind. Ill start shopping for a different intake, had the Vicky on the shelf so I figured I might try it but figured with the small cubes it would kill what bottom it might have. I think I stick with the cam as its already in and everything assembled around it minus the intake. If it sucks that bad ill only have to live with it for a year;) .
paperman
Post  supervel45 January 18th 2016, 12:53 am
https://fordperformanceracingparts.com/parts/part_details.asp?PartKeyField=6587 SCJ heads with 850DP/Victor 550HP
Post  away January 18th 2016, 10:48 am
If only for a year a I wouldnt waste the time on buying a new intake.....I would use what I have......carb fine.....go play!
away
away
Post  rmcomprandy January 18th 2016, 11:30 am
supervel45 wrote:https://fordperformanceracingparts.com/parts/part_details.asp?PartKeyField=6587        SCJ heads with 850DP/Victor 550HP
YES ... I was going to the same place. That build is real similar to the former Ford Racing crate engine which was tested with a big 4150 model carb.
For this engine your headers are a bit to big.
