FFP dual plain intake question.
I'm working on a PI headed 460 ci engine. Just a mild set up. Hydrolic comp magnum cam flat top pistons cj valves. My question is have any of you run a FPP dual plain intake befor ?? If so what did you
Think.
Think.
Re: FFP dual plain intake question.
dr's wife racing wrote:I'm working on a PI headed 460 ci engine. Just a mild set up. Hydrolic comp magnum cam flat top pistons cj valves. My question is have any of you run a FPP dual plain intake befor ?? If so what did you
Think.
That intake manifold is simply a re-branded "Performer RPM".
Okay, it should be fine for a mild build. Thanks
dr's wife racing wrote: Okay, it should be fine for a mild build. Thanks
Magnum cam sux in a BBF, single pattern. Even though the PI head has the best exhaust, it still needs 4-6 more degrees duration @ .050 to really work good.
Blake I bought this as a abandoned project. Something to do while my neck heals up. All brand new stuff just some assembly required. I plan on going with what it came with due to cost. I have no idea what I'm going to do with it. I think it would make a pretty decent street motor for someone.
Just curious, what would it do if I put a 1.8 rocker on the exhaust
» Question on a dual plane intake on a 557
» Question on dual pattern camshafts
» Dual carb intake
» 429/460 Dual Quad Intake Height
» Dual carb intake
