Cam Info
Cam Info Empty Cam Info
Post  Mark Laczo February 19th 2016, 9:44 pm
Gotta cam that needs a little deciferin. Any idea's ?
1302R/1968R
R113
CC L0829-07
2855 A
I am thinking a comp cam ground on a 113 lobe sep ? guessing ?
Thanks Mark
Mark Laczo
Mark Laczo
Cam Info Empty Re: Cam Info
Post  Lem Evans February 19th 2016, 11:24 pm
Mark Laczo wrote:Gotta cam that needs a little deciferin. Any idea's ?
1302R/1968R
R113
CC   L0829-07
2855 A
Thanks Mark
284*/.470"
302*/.450"
113* LSA
Comp Cam
Ground in 2007
Post  Mark Laczo February 20th 2016, 12:26 pm
Thanks Lem,
I got the Manley "Blue Strip" springs 221424.
You think they would work on that cam ?
I could give Comp a call on Monday and see what they recommend for springs.
Its for a set of Motorsport A460 heads.
Mark Laczo
Mark Laczo
Post  Lem Evans February 20th 2016, 1:14 pm
Mark Laczo wrote:Thanks Lem,
The b.s. springs will work. Set them up a little short so that they will not be so far above coil bind.
Post  dfree383 February 20th 2016, 1:32 pm
Might want to consider the green stripes with that cam.
Post  Lem Evans February 20th 2016, 5:39 pm
dfree383 wrote:Might want to consider the green stripes with that cam.
You mean the ones that set up at 2.100"?
Post  Mark Laczo February 22nd 2016, 10:12 am
Okay good that's what we did, just making sure I'm going the right direction.
I'm running the "Green Stripes" on my C-heads for that 2.1" installed height with a .880"ish lift cam.
Mark Laczo
Mark Laczo
