trick Flow intake manifold
trick Flow intake manifold Empty trick Flow intake manifold
Post  rmcomprandy February 29th 2016, 1:49 pm
Does anyone have any feedback on the performance of the 289/347 intake manifold for a small block Ford with the 4150 carburetor flange #TFS-52400111 ...?
trick Flow intake manifold Empty Re: trick Flow intake manifold
Post  gmsmkr February 29th 2016, 3:00 pm
No feed back yet randy but..
We should have some results in 3 weeks we are swapping out the parker funnel web to that R intake and see how it works
gmsmkr
gmsmkr
Post  rmcomprandy February 29th 2016, 6:28 pm
gmsmkr wrote:No feed back yet randy but..
I am really interested for what to start with on next year's Engine Masters 347 engine; gotta go to 7,500 RPM.
Post  gmsmkr February 29th 2016, 6:57 pm
The parker we are using takes a lunch at 7,300 on our combo you could probably get more than me out of one with your porting knowledge. This is if you can find a real parker not the chines knock off crap
gmsmkr
gmsmkr
Post  gmsmkr April 22nd 2016, 12:17 pm
Well we did not pick up nothing with our deal swapping intakes from the parker to the box stock TFS R intake it is back off and going to do some porting and see where it lands us...
So to sum it up
Ported parker vs TFS R
We lost nothing and gained nothing with our combo on a 312" small block RHS heads with a erson solid cam
gmsmkr
gmsmkr
Post  rmcomprandy April 22nd 2016, 3:54 pm
gmsmkr wrote:Well we did not pick up nothing with our deal swapping intakes from the parker to the box stock TFS R intake it is back off and going to do some porting and see where it lands us...
So to sum it up
Thanks for the feedback ... I will be going to proceed in that direction now for a starting place mainly because it seems like it would be an easier modification to transition for a Dominator carb pad with the allowed only 1" spacer.
This Engine Masters combo has a 4.037" bore and 3.435" stroke in an 8.2" deck block with Kaase P-38 heads.
