AN line for radiator
Will 8AN line be big enough to feed a big block
gmsmkr- Posts : 1364
Re: AN line for radiator
I've used -10 before with no problems.
jbozzelle- Posts : 3705
This is for a alky motor has a shogun pump with 3/8 npt ports
I use 2 8's run in the front of the block with remote pump.
cool40 wrote:I use 2 8's run in the front of the block with remote pump.
This is what I had in mind is there a way I can get a pic of how yours is set up please... also what size are you running from the t Stat housing back to the radiator
» Water tank in trunk.
» Radiator ?
» Good C6 Line Pressure at 1000 rpm? And more... Stacked shift, Line pressure not changing at different vac levels
» Radiator
» radiator cap
» Radiator ?
» Radiator
» radiator cap
