ARP main stud ?s
ARP main stud ?s Empty ARP main stud ?s
Post  79bronco March 5th 2016, 12:16 am
I have a nice C8VE block that I am using for my build that has been outfitted with ARP main studs.
My issue is this, I am using a rear sump pan for my Bronco and the ARP studs don't have the correct stud to hold down the rear sump pickup.
What do you do?
79bronco
ARP main stud ?s Empty Re: ARP main stud ?s
Post  supervel45 March 5th 2016, 12:25 am
Can you fab a new bracket and weld or braze it to the pickup tube, not quite understanding the situtation?
Post  79bronco March 5th 2016, 12:33 am
On the factory bolt there is a small stud on it that hold down the tab of the pickup tube. The ARP doesn't have this, so how do I fasten down the tab?
79bronco
Post  supervel45 March 5th 2016, 12:44 am
If it where me, I would call ARP and see if they would help you out and sell you a correct stud for the application.
Post  BOSS 429 March 5th 2016, 1:01 am
One thing you can do is drill and tap a hole in the girt frame bolt it down, done.  2nd  make a new bracket and  install it under the nut for the stud,
3rd you can order a new stud with a little stud on the end of it.
Post  79bronco March 5th 2016, 11:32 pm
#3 is what I was looking for, thanks Rich
79bronco
