Minimum valve to valve clearance
Hi,
During overlap, the minimum clearance between the valves measured with a feeler gauge is .032". Is this an acceptable clearance?
I came up with this figure by mapping out the closing and opening events, then removing the head and using dial indicators, measuring the clearance at .010" increments as the valves passed each other.
The heads are D0OE-R iron SCJ heads with 2.25 and 1.76 valves.
On the net, I found limited info on this, and some people have stated .030" is okay and maybe less depending on guides and springs and such. I think they may have been referring to inline valve arrangement. So, I am wondering if the canted valve arrangement needs more clearance.
69BOSS- Posts : 75
Re: Minimum valve to valve clearance
The number I have heard is .040" between the canted valves when they are seated. However, it's really a function of camshaft duration more than anything, so it's seems to me that it would vary somewhat on each engine.
What I would do is mock up. Install the proper cam, the assembled heads, rocker arms, pushrods, set your lash and etc.. Then with the engine upside down on the engine stand, and a empty cylinder without rod and piston, turn the cam over slowly and see how close the valves come to each other during overlap. Physically measure the clearance between them with a feeler gauge, at their closest point.
There are several things you can do to reduce a valve clipping problem. Unfortunately we all had to learn this the hard way with that batch of old A-429 heads, where the machining slipped /moved, allowing the valves to clip with big roller cams. Those were serial numbers 2000 through 5000 if my memory is correct. Things such as opening up the lash, a new valve job sinking the valves a little, also beveling the edge of the valve, margin to face, reducing the diameter of the valves. etc,
Hope this helps,
Charlie
Hope this helps,
Charlie
c.evans- BBF VENDOR SPONSOR
Odd you always hear about this with A429 heads but, I don't ever recall hearing about it before and CJ/SCJ's have been around since 1970 with big valves or at least 1.72's.
supervel45- Posts : 4498
I believe the specs from FRPP for a 521" with a "C" head was .035 min.
FalconEh- Posts : 1448
Thanks for the info.
Staci
Staci
69BOSS- Posts : 75
» what is the minimum radial clearance for piston to valve clearance?
» Federal Minimum Wage
» Valve job..
» Going from Ferrea 2.20 valve to 2.25, Is there a better flowing valve for ported STREETS?
» Exh VAlve ?
» Valve job..
» Exh VAlve ?
