Valve job..
+6
95lightiningguy
bb429power
OldRedFord
10 posters
Valve job..
Do you guys think I made a bad move by not doing a valve job on my
heads? None of the valves were burnt, none of the seats or the sides of
the valves looked to be buggard up. The guides do not seem to have
excessive wear. I have changed out the valve springs for new ones.
If I was going to do a 3 angle valve job I would have the heads cut for
bigger valves, upgrade to stainless valves, have the guides replaced
and cut for p/c seals, more intensive porting, and have the shop put
the heads together and set the spring height.
But I do not have that kind of cash right now and just want to drive the dang truck.
OldRedFord- Posts : 465
Re: Valve job..
If you don't have the cash then run what you got..... Got to start somewhere.
Re: Valve job..
I would hand lap them and check to see if they were sealed by pouring lacquer thinner into the ports. If they leak, you need to touch them up. I know this is old school , but if your on a tight buget, you do what you can.
But if they leak, you need to fix them, before they go back on.
Re: Valve job..
Lap them real good. You know how to do it right? Its easy but I don't want to type it all up to find out you already know how it done.make sure you get the tool to do it though, when your done doing it you will be very good at making fires though.
bb429power- Posts : 3129
Re: Valve job..
Thats why I use a cordless drill and go real slow both directions counting turns as I go.bb429power wrote:Lap them real good. You know how to do it right? Its easy but I don't want to type it all up to find out you already know how it done.make sure you get the tool to do it though, when your done doing it you will be very good at making fires though.
95lightiningguy- Posts : 570
Re: Valve job..
95lightiningguy wrote:Thats why I use a cordless drill and go real slow both directions counting turns as I go.bb429power wrote:Lap them real good. You know how to do it right? Its easy but I don't want to type it all up to find out you already know how it done.make sure you get the tool to do it though, when your done doing it you will be very good at making fires though.
X2 on the cordless drill
res0rli9- BBF CONTRIBUTOR
Re: Valve job..
dfree383 wrote:If you don't have the cash then run what you got..... Got to start somewhere.
X2 and do lap the valves if you have on leaking take a rubber hammer hit the top o the valve hard enough to make it open but not hard enough to drive it out of the bottom of head if this does not stop the leak it relap it
Jim
Re: Valve job..
Just interested, don't mind me. Didn't hear about the lacquer thinner or rubber hammer tricks....
MBBFord- Posts : 32
Re: Valve job..
I did lap the valves. Got the suction cup tool and the grinding compound. Spun the valves back and forth. Looked pretty nice.
I swore I took pictures but cant find them.
Oh ya a guy on another site said that lapping valves was for third world countries.
I will do the languor thinner thing and check my work.
Re: Valve job..
OldRedFord wrote:I did lap the valves. Got the suction cup tool and the grinding compound. Spun the valves back and forth. Looked pretty nice.
I guess he should go back to his world where money grows on trees
» Going from Ferrea 2.20 valve to 2.25, Is there a better flowing valve for ported STREETS?
» Exh VAlve ?
» How do you check valve to valve clearance????
» Minimum valve to valve clearance
» Do the bare P-51's come with a valve job?
» Exh VAlve ?
