Fairmont 472 Eddy head 649hp index car ......9.77 @132mph 10/31/18 *added videos
+25
DanE
90lxcoupe
whitefield
larry552
Mustang-junky
pmrphil
351crules
biglucky
away
captaingriffin
Gregaust
gmsmkr
5pointslow
29 posters
Page 4 of 7
Page 4 of 7 • 1, 2, 3, 4, 5, 6, 7
Re: Fairmont 472 Eddy head 649hp index car ......9.77 @132mph 10/31/18 *added videos
Swap on a 29" inch tire, trade the 4:10 for a 3:73 and add a NOS 150 hit and I can see 9-teens and 9.20's happening!!
BBFTorino- Posts : 997
i ordered a set of M&H slicks yes m&H ......28.5 x 10.5 not stiff sidewalls
going to give these ago , John at m&h one of the nicest guys to deal with
in new england this is the longest part of the year january to april boy does it drag ass!
5pointslow- Posts : 1401
going sunday to give it hell
going to do a couple all out passes then going to slow it up for index class
April 20th is the first race
excellent...let us know how you do
351crules- Posts : 11
Congrats, looks good.
biglucky- Posts : 213
that pass went 9.82 at 133 mph
5pointslow wrote:that pass went 9.82 at 133 mph
Nice pass ! What does that thing weigh ? Pm me your total build gear ratio stall speed trans type. I have the engine specs just need the rest.!
whitefield- Posts : 2244
That was a nice, clean pass. Contrats
Mike R- Posts : 1381
Nice pass ,congratulations
90lxcoupe- Posts : 12
Nice run,not sure if you mentioned it before but what brand headers are you using and are you using a Engine plate or Motor Mounts?
![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif)
Mark Miller- Posts : 1946
Mark Miller wrote:Nice run,not sure if you mentioned it before but what brand headers are you using and are you using a Engine plate or Motor Mounts?![]()
using solid motor mounts , with a engine limiter to frame
using hooker fox swap super comps that are dented
set up is pretty simple but seems to be all working
5pointslow wrote:Mark Miller wrote:Nice run,not sure if you mentioned it before but what brand headers are you using and are you using a Engine plate or Motor Mounts?![]()
So I take it the Hookers don't fit the greatest?I have MAC Headers on my car now but they're over 20 years old I used them on my 88 T-Bird 460 swap back in 1997!!
the hookers work but with the jw bell on the glide its tight and needs to be massaged a bit
i think the hookers were designed for using a c6 in mind
Very nice, congrats!
windsor- Posts : 1167
5pointslow wrote:the hookers work but with the jw bell on the glide its tight and needs to be massaged a bit
I have a C-4 in my car so maybe they might not fit to bad!!
In the last video that you posted, it sounded like the engine leveled out and did not continue to increase it's pull the last few hundred feet of the run.
DanE- Posts : 90
DanE wrote:In the last video that you posted, it sounded like the engine planed out and did not continue to increase it's pull the last few hundred feet of the run.
That is usually the way to the quickest times, simply not the highest MPH.
Thank you for the insight Randy.
DanE- Posts : 90
DanE wrote:In the last video that you posted, it sounded like the engine leveled out and did not continue to increase it's pull the last few hundred feet of the run.
I agree 100% it pulls hard and hits a point that it flattens out
from 1/2 track on its not hard puling feeling vs the front 1/2
Possibly low on timing. If you’re using a distributor for timing they will climb the cam gear at higher rpm and can retard the timing quite a bit. I actually measured 4-6 deg swing in mine before I went to crank trigger. Just something to think about.
stanger68- Posts : 492
Makes 649hp
Weighs 2900 with me
I mean 472 with a solid lifter cam I think it's doing all that's being asked and I assume would flatten out and not pull anymore at some point
Gone 9.77 and prob has a 9.70 or maybe a 9.60 but I'm not sure how much is left
Timing is at 32 or 33 I'd have to double check
I'm having alot of fun so far really been appreciate advice and help I have gotten on here
ANDY
Weighs 2900 with me
ANDY
Check yer plugs....
rbro460- Posts : 102
» How About Another LS Fairmont????? NOT! Video Added
» New Eddy Heads?
» Eddy head 460 with icon pistons
» 85 Mustang SFI cert. 25.4 good to 7.50[videos added]
» I made it back from the track...... Videos added....! :-)
» New Eddy Heads?
Page 4 of 7
