stuck in low rang
Re: stuck in low rang
BW-1356 transfer case? There is a little tab that holds the oil pickup tube down that actually rides on the shaft. It's thin sheet metal and I've had it bend up and get caught making it so my case was stuck in low range as well. Might be time to pull the case and open it up.
kjett- Posts : 1169
Got the case fixed... The hole in the case for the shift shaft was wore big time... My buddy has a transmission shop rebuilt it for me... New seals, the gear for the shift fork and he called it a case saver washer.
» Stuck piston...AKA Im an idiot
» Stuck in KY need drag races.
» Stuck low reverse clutch piston in a C6
» Stuck booster valve sleeve
» I'm stuck in Edmonton, Alberta for the next couple of days
