Stock cam + Ported DOVEs + Victor = ?
I have a 96ish EFI shortblock that seems to be in good shape that I'm planning on slapping together with a set of fully ported Doves (with 2.25in 1.71 ex valves), a Victor, an SV1 100mm (or 105 I forget now) carb, AND the stock cam... I'm just using parts that I have to get it going so I can drop it in my 71 Torino and get the car sorted enough to do a full 547 P51 build.
I know that the Victor and Doves aren't a great match (and I should mention that it has already been port matched to my set of P51s), but this isn't a race car. I also know the stock cam is tiny but I don't wanna spend money on a temporary setup, plus a bigger cam would require notching the pistons for the big valve Doves.
I think the stock EFI shortblock with the Doves should give me about 10.2:1 compression and a dynamic compression of about 8.3:1 which both seem healthy enough to run well.
My question is will this package run well enough for cruising and a little fun or should I use a stealth and QFT 950 I also have? I rather use the Victor and SV1 because thats what I'll be using on the 547, plus they'll look cool. I don't have to use the Victor if it's just gonna run like **** but if there is likely only a moderate performance difference then I'll just stick with my plan.
The car is a 1971 Torino with a T56 (6 speed) and a 3.55 Locker out back. The exhaust will be 2 inch primary custom mid length headers (have to get around a rack and pinion conversion) with full 3 inch dual pipes all the way back.
SLord82- Posts : 145
Re: Stock cam + Ported DOVEs + Victor = ?
Save the intake and carb put it on the shelf
A performer rpm and a 950 will be sufficient for what your looking for and run well with bottom end power in a driver
No matter what the rear gear is it will love to pull
gmsmkr- Posts : 1364
My question isn't which setup is best in this scenario. My question is, will the Victor and big carb run like shit with this setup? Is it going to totally bog down all the time on the street or should it run well enough with decent compression and the professionally ported heads?
It may run okay, but it will very likely be "soft" down low and throttle response will be mediocre.
Don't think a Victor and carb will fit under the stock hood though!!
But give it a try and see how you like it.
BBFTorino- Posts : 997
SLord82 wrote:My question isn't which setup is best in this scenario. My question is, will the Victor and big carb run like shit with this setup? Is it going to totally bog down all the time on the street or should it run well enough with decent compression and the professionally ported heads?
Sure sounds like your asking which is better to me.... put the stuff you got on it and drive it if that's what you want
![Rolling Eyes](https://2img.net/i/fa/i/smiles/icon_rolleyes.gif)
BBFTorino wrote:It may run okay, but it will very likely be "soft" down low and throttle response will be mediocre.
Thanks, this is the feedback I'm looking for.
From what I've seen the Stealth is 6.25 tall and the victor is 6.75 but the SV1 is about half an inch shorter than a typical carb so hopefully its a wash. I was able to get the stealth and a 950 under a GT hood with a drop base air filter setup. So I think I can get the victor and sv1 under there with some creativity. With the factory scoop on the hood, that lends itself to a creative intake setup.
Hopefully its not too much of a dog down low, but would a small cam affect it that much?
gmsmkr wrote:SLord82 wrote:My question isn't which setup is best in this scenario. My question is, will the Victor and big carb run like shit with this setup? Is it going to totally bog down all the time on the street or should it run well enough with decent compression and the professionally ported heads?
Sure sounds like your asking which is better to me.... put the stuff you got on it and drive it if that's what you want![]()
Its not, but i do appreciate any input. Sorry if my original post was unclear.
I'm just concerned that a victor and big carb will run terrible with a stock shortblock. I'll likely move forward with my plan unless someone has experience saying it'll just be a dog. It's definitely not the typical setup, so I'm sure most people won't have first hand experience with this.
It will be a dog..... my original post.... not because of tthe intake or carb BUT the stock cam is what's going to kill it
SLord82 wrote:My question isn't which setup is best in this scenario. My question is, will the Victor and big carb run like shit with this setup? Is it going to totally bog down all the time?
YES ... and not much fun to drive.
EDIT: Totally mismatched ... use it all that way so you can find out for yourself.
gmsmkr wrote:It will be a dog..... my original post.... not because of tthe intake or carb BUT the stock cam is what's going to kill it
rmcomprandy wrote:SLord82 wrote:My question isn't which setup is best in this scenario. My question is, will the Victor and big carb run like shit with this setup? Is it going to totally bog down all the time?
Thanks Randy. I figured it was bit mismatched but didn't know how bad. If its gonna run bad and not be any good to drive I'll stick with the stealth and a 950 for now.
For drive ability you would be better off using a stock intake and a 750 cfm carb. With the stock cam, even with the Stealth and a 950 I think it will still be a dog. My SCJ Torino stock, only took an 850 cfm. But try it and see.......
jeffgfg- Posts : 338
jeffgfg wrote:For drive ability you would be better off using a stock intake and a 750 cfm carb. With the stock cam, even with the Stealth and a 950 I think it will still be a dog. My SCJ Torino stock, only took an 850 cfm. But try it and see.......
You know I hadn't thought about using a stock intake. I might have a 4v truck intake I could try. The smallest carb I have is an 850 demon that needs a rebuild. Might try the stock intake and 950, as I'm working 460 cubes vs your 429.
Randy, any thoughts about this option?
A stock O.E.M. intake manifold would probably drive great.
Block off the exhaust cross-over and use a 4 hole 1" thick spacer under your 850.
The stock intake may have the best drivability, but the effort to put that heavy beast on there is unwelcome!!
Just grab an Edelbrock Performer if you're going to do that!!
Even a nice used one. I see them often on craiglist usually for under $125
BBFTorino wrote:The stock intake may have the best drivability, but the effort to put that heavy beast on there is unwelcome!!
If I were to spend money on it I'd get the pistons fly cut for a bigger can. Trying to spend as little as possible on it though.
rmcomprandy wrote:A stock O.E.M. intake manifold would probably drive great.
Any reason for a 4 hole versus a open spacer?
SLord82 wrote:rmcomprandy wrote:A stock O.E.M. intake manifold would probably drive great.
YES ... but, try both and use whatever you want after you learn the difference for yourself.
» Fully Ported Kaase Victor 4500 Intake Man
» 545 ported doves 675hp at 5700 707tq at 4400
» Is there any gain using a ported victor 4500 when using a 4150 carb and adapter?
» wanted ported victor 460
» Ported Victor intake pictures
