545 ported doves 675hp at 5700 707tq at 4400
Re: 545 ported doves 675hp at 5700 707tq at 4400
Congratulations!
Do you have the flow numbers of the heads? What size valves?
What compression?
With an intake/exhaust ratio of somewhere around .6, it would seem like you would want a camshaft with a large split between the intake duration and exhaust duration so as to let the cylinder "blow down" at higher RPMs. I believe that camshaft left power on the table. More carb!
What compression?
DanE- Posts : 90
no flo #s home port ex bumps out victor match int 13.8 comp 2.19 1.76 fierra valves i did the block oil mods and engine assembly 2 dowel pin cam gear upgraded to 1/2 in retaining bolt no elect water pump alternater also turning manual fuel pump had 5 1/2 lbs stock dist had 1150 dom max was 658hp 687 tq the 950 stomped it i wanted stock valve covers but wouldt clear girdles they was laughing at it when i got to there shop mudd falling off some of the used parts from last year 1.78 headers that's what we had at the time
ironhead71- Posts : 3
Good numbers especially for a single pattern cam. The early peak given the duration suggests a lack of intake port imo.
Do a 270 / 290 split and you will not only find HP but extend your usable RPM range.
S
S
thanks for the info im open to suggestions working on another one now and can post pics of ports and will have victor intake on it u talking a custom cam or off the shelf
Custom! Not an off the shelf "Chevy" grind for your Ford. Your Ford has different requirements.
DanE- Posts : 90
Very nice. I wonder how much the port job is worth over a set of stock runner heads? Just out of curiosity.
At 13.8 to 1 I think there is more in it but would need to to know the flow numbers.
Straubtech- Posts : 293
» Dove heads on stock 460
» Stock cam + Ported DOVEs + Victor = ?
» WTT: Ported D0VE's for ported D3's
» used trend 8.750 push rods .080 wall $45.00
» WTB a set of ported dove heads
