Aftermarket Aluminum Heads--Not Pro Comp
James Hahn
john boschma
1EFF100
Just throwing this out there to see if any of you gentlemen may have a second hand set of SCJs, Blue Thunders, TFS streets etc. laying around you'd care to turn loose of. Maybe you upgraded and have something from your old build sitting on the shelf or something. I know it's a long shot but just checking.
Thanks.
Bruce
Thanks.
Bruce
1EFF100- Posts : 265
Re: Aftermarket Aluminum Heads--Not Pro Comp
If you haven't found anything yet, I have a complete top end.
Original aluminum cobra jet heads with port work. Just freshened up last summer have two passes on them since.
Manley springs, 300# on the seat, 850# open, titanium retainers.
4150 Victor intake which is brand new.
1.73 rockers and stud girdle.
Ask for $2000
You can call or text me at 608-346-4015 if interested.
The parts are still on the engine.
Ask for $2000
john boschma- Posts : 16
1EFF100 wrote:Just throwing this out there to see if any of you gentlemen may have a second hand set of SCJs, Blue Thunders, TFS streets etc. laying around you'd care to turn loose of. Maybe you upgraded and have something from your old build sitting on the shelf or something. I know it's a long shot but just checking.
Thanks.
Bruce
I have a whole engine 472 Aluminum CJ Heads {Ported) and a Powerglide to go with it Makes great power and dependable. Let me know I will give you a good deal for Both. Getting out of Racing...
James Hahn- Posts : 23
Thanks for the offer James but I don't need a complete engine, I already have enough pieces to bolt a 545 shortblock together. And, as always, I'm on an extremely tight budget with very little fun money for car stuff.
I should add the heads don't need to be anything super-duper high-performance as they are going on a low RPM hydraulic cam street engine 545 designed to yank around a heavy '74 Cougar.
Thanks.
Thanks.
Re: Aftermarket Aluminum heads
I have a set of 95cc chamber Edelbrock heads for sale. Heads have been ported by the Madporter. Asking $1,000. Located in South Lyon, MI 48178
Chris
Chris
chris532- Posts : 22
Chris532, PM sent.
I have a set of A429 heads I'll be selling next month. Just put all new springs, locks and retainers in last weekend. Have flow data on them also. Will be looking to get $1300-$1400 for the set.
Unfortunately the chambers are too small. I need something in the 95-100cc range.HorsinAround wrote:I have a set of A429 heads I'll be selling next month. Just put all new springs, locks and retainers in last weekend. Have flow data on them also. Will be looking to get $1300-$1400 for the set.
I have recently purchased a set of factory Police Interceptor iron heads which at 86cc are still too tight. If a set of aluminums don't show up before assembly begins, I'm afraid I'll be ordering new dished pistons.
Thanks for the offer.
I should add, the previous 545 was sold and I'm now assembling a 521 with flat tops--if I can get away with it.
1EFF100 wrote:Unfortunately the chambers are too small. I need something in the 95-100cc range.HorsinAround wrote:I have a set of A429 heads I'll be selling next month. Just put all new springs, locks and retainers in last weekend. Have flow data on them also. Will be looking to get $1300-$1400 for the set.
1EFF100 wrote:I should add, the previous 545 was sold and I'm now assembling a 521 with flat tops--if I can get away with it.
Not sure what you are building, but I currently have these heads on on a 514 (4.150 stroke, .080 bore) with flat tops.
HorsinAround wrote:1EFF100 wrote:Unfortunately the chambers are too small. I need something in the 95-100cc range.HorsinAround wrote:I have a set of A429 heads I'll be selling next month. Just put all new springs, locks and retainers in last weekend. Have flow data on them also. Will be looking to get $1300-$1400 for the set.
Thanks for the offer.1EFF100 wrote:I should add, the previous 545 was sold and I'm now assembling a 521 with flat tops--if I can get away with it.
The engine is going in a heavy street car and needs to run on 91 pump gas.
HorsinAround, I'd be interested in that set you have! Let me know!
Boyd10- Posts : 17
im looking for a GOOD SET of aluminum heads for light duty in a blown street rod
I have a new home available for Aluminum heads, (stud. ports) and a blower and manifold for D3VE block, hit me back if you can help.
Thanks!
Thanks!
Myjack- Posts : 8
» PROCOMP HEADS ------ STICKY------
» Aftermarket Aluminum Head That Fits This Description
» FS: New set of Ford M-6049-SCJA aluminum cylinder heads.. HEADS SOLD, Thx
» Aftermarket cast iron heads
