Aftermarket Aluminum Head That Fits This Description
fc2444
1EFF100
Aftermarket Aluminum Head That Fits This Description Empty Aftermarket Aluminum Head That Fits This Description
Post  1EFF100 March 25th 2018, 9:09 am
Make good power and torque on a 521 with flat top pistons (looking for at least 600 HP), maximum RPM of 6000-6500, run on 91 octane California pump gas, corresponding intake able to fit under hood with air cleaner, delivered to my house ready to bolt on for $2500.00.
Is there anything?
As always thanks for any and all replies.
Bruce
1EFF100
1EFF100
Aftermarket Aluminum Head That Fits This Description Empty Re: Aftermarket Aluminum Head That Fits This Description
Post  Lem Evans March 25th 2018, 10:28 am
1EFF100 wrote:Make good power and torque on a 521 with flat top pistons (looking for at least 600 HP), maximum RPM of 6000-6500, run on 91 octane California pump gas, corresponding intake able to fit under hood with air cleaner, delivered to my house ready to bolt on for $2500.00.
Is there anything?
Bruce
Most all of the USA make stuff does that 600+easy. But, you are eliminating all of the 72cc chamber stuff due to the flat tops/91 oct.
Post  1EFF100 March 25th 2018, 10:45 am
Is there anything?
Bruce
That's kinda what I thought, Lem. Crying or Very sad I was hoping I may have missed a large chamber head in this category.
I wish the Blue Thunder stuff was still around. They used to have a 100cc chamber option, didn't they?
1EFF100
1EFF100
Post  Paul Kane March 25th 2018, 12:33 pm
The Edelbrock 95cc heads are your best bet. In fact I did a similar 545 with a very small hydraulic flat tappet cam that managed 582hp/670tq with out-of-the-box unported heads and an 850 Holley. None of the engine parts been rubbed on and the flat tappet cam was smaaaall.  A 600 hp 521 with 95cc Edelbrocks would be easy. With enough effort you could even hit your marks with well modified D3s if you wanted (thanks to the proposed $2500 budget).
The Blue Thunder 100cc heads are a round, open chamber head intended for blower applications. In most cases they are not the first choice for an engine of moderate compression ratio that will be run on straight California pump gas.  Just sold a fully polished set of those by the way. They really are a nice cylinder head option to have around.
Post  1EFF100 March 25th 2018, 1:41 pm
Paul Kane wrote:The Edelbrock 95cc heads are your best bet. In fact I did a similar 545 with a very small hydraulic flat tappet cam that managed 582hp/670tq with out-of-the-box unported heads and an 850 Holley. None of the engine parts been rubbed on and the flat tappet cam was smaaaall.  A 600 hp 521 with 95cc Edelbrocks would be easy. With enough effort you could even hit your marks with well modified D3s if you wanted (thanks to the proposed $2500 budget).
Thanks Paul. I have a set of Police Interceptor heads I was going to send up to Scotty to work on when I was thinking of going all cast iron but since the initial build began, I figured I'd have a better chance with aluminums to fight off the detonation monster. Plus, aluminum DOE'S look cool. Very Happy
1EFF100
1EFF100
Post  fc2444 April 13th 2018, 3:53 pm
Paul I don't guess you have another set of BT heads do you. I eed a set for a blower motor I am doing
fc2444
http://amr-coatins.com
Post  rmcomprandy April 13th 2018, 4:38 pm
Is there anything?
Bruce
Edelbrock has a head that will work well with 91 octane gasoline and flat-top pistons.
EDIT:
I should have read the whole thread first ... oh, well.
Post  Paul Kane April 14th 2018, 4:30 pm
fc2444 wrote:Paul I don't guess you have another set of BT heads do you. I eed a set for a blower motor I am doing
Unfortunately no, sorry.  You can essentially (generally) get the same results by running the piston about 0.100" below deck with a quench-padded cylinder head.
Post  Paul Kane April 16th 2018, 3:04 pm
For those who might have never seen them, here are the chambers of the Blue Thunder 100cc heads. Cool
Aftermarket Aluminum Head That Fits This Description Bt100c10
Post  1EFF100 April 16th 2018, 8:32 pm
Thanks Paul. Smile
1EFF100
1EFF100
Post  Mark Miller April 16th 2018, 11:04 pm
Paul Kane wrote:For those who might have never seen them, here are the chambers of the Blue Thunder 100cc heads.  Cool
Those are big chambers never seen them before thanks for the picture Paul!!! Smile
Post  BBFTorino April 17th 2018, 1:34 am
They kinda remind me of the D2AE open chamber heads that run awful. But I'm sure Blue Thunder stuff is much better chamber wise!!
Post  dfree383 April 24th 2018, 4:11 pm
BBFTorino wrote:They kinda remind me of the D2AE open chamber heads that run awful. But I'm sure Blue Thunder stuff is much better chamber wise!!
Same garbage, its the application that the chamber works on, you don't need quench with forced induction
