aluminum head question
aluminum head question Empty aluminum head question
Post  mustangjeff October 12th 2010, 9:36 am
Can I use the stock head bolts on aluminum heads if not using nitrous & also the heads I bought are the a429 cobra jets with roller springs can I use those springs with a flat tappet non roller cam? Maybe stupid question but I do not know the answer.
mustangjeff
aluminum head question Empty Re: aluminum head question
Post  richter69 October 12th 2010, 10:35 am
Yes on the bolts, no on the springs.
Post  dfree383 October 12th 2010, 11:00 am
Need to get hardened washers to use the factory head bolts, if the heads are not equiped with steel inserts.
x2 on the springs the roller stuff will kill a flat tappet pretty quick, get the springs to match the cam you have.
