fuel pump 600 hp give or take .. best bang for the buck
+14
gmsmkr
BigRigTech
cheatham
J.Toney
tbirdmike
D. Sea
manofmerc
Carl
FORDMUD
norm
5pointslow
18 posters
fuel pump 600 hp give or take  .. best bang for the buck  Empty fuel pump 600 hp give or take .. best bang for the buck
Post  5pointslow March 23rd 2016, 6:40 am
was wondering
bang for the buck fuel pump to support 600-625 hp range to feed a dommy
not looking to spend crazy money on a magnafuel setup
not looking for a jegs cheapy either or knock off
5pointslow
5pointslow
fuel pump 600 hp give or take  .. best bang for the buck  Empty Re: fuel pump 600 hp give or take .. best bang for the buck
Post  norm March 23rd 2016, 6:53 am
Aeromotive A1000 is a good pump that isn't a million dollars,and it will support more power than you're looking for so there is room to grow.
norm
norm
Post  FORDMUD March 23rd 2016, 7:00 am
I'd go with an Aeromotive of some sort. I was very pleased with their customer service when I had a problem with an A2000 pump.
FORDMUD
FORDMUD
Post  Carl March 23rd 2016, 10:10 am
I've had good luck with the Holley HP125 and HP150 pumps.
Carl
Post  5pointslow March 23rd 2016, 10:20 am
Carl wrote:I've had good luck with the Holley HP125 and HP150 pumps.
thanks i was looking at this one
https://www.holley.com/products/fuel_systems/fuel_pumps_regulators_and_filters/fuel_pumps/carbureted_electric_fuel_pumps/parts/12-125
5pointslow
5pointslow
fuel pump 600 hp give or take  .. best bang for the buck  Empty Holley black
Post  manofmerc March 24th 2016, 3:44 am
I was having fuel starvation issues on my 460 running 6.80s in the 1/8 went with a holley black and all is good for me .It was running out of gas after I installed a victor intake .Doug
manofmerc
Post  5pointslow March 24th 2016, 3:49 am
manofmerc wrote:I was having fuel starvation issues on my 460 running 6.80s in the 1/8 went with a holley black and all is good for me .It was running out of gas after I installed a victor intake .Doug
what fuel pump were you using when you were having troubles
5pointslow
5pointslow
Post  D. Sea March 24th 2016, 5:16 am
I'm still running Two Mallory comp 140 fuel pumps. Both over 20 years old and they just won't quit. Geo Rotor Designed like an oil pump so they will last "forever". Key to keeping them alive is to keep your fuel clean with a good filter before the pumps.
D. Sea
D. Sea
Post  tbirdmike March 24th 2016, 11:38 am
holley or summit black pump should do ya with a holley regulator. 6psi fuel pressure.
Just make sure the pump is fed from a rear sump tank and the pump mounted flush or below the tank.
These pumps are not pullers.  They are pushers.
tbirdmike
Post  J.Toney March 24th 2016, 6:03 pm
A1000
J.Toney
J.Toney
fuel pump 600 hp give or take  .. best bang for the buck  Empty I was running an engine driven pump
Post  manofmerc March 26th 2016, 2:36 am
I had a big carter mech.then I went with a holley 130gph mechanical pump it would run out of gas right after the end of the 1/8 mile marker .This happened after I went from a performer rpm air gap intake to a victor .I bought the holley electric black pump. I believe it is 140 gph .It costs a little more than a holley blue but has more gph .It is really for alcohol But works fine with regular gas. I run aluminum 3/8 fuel line and A.N. fittings .I don't have 600-650 hp maybe 500-550 maybe not a fair comparison but close as I can get .On a good day it will go 120mph @3400lbs.Lot of fuel pumps for 600 hp engines Quick fuel has a couple of nice ones too.Doug
manofmerc
Post  cheatham March 26th 2016, 5:40 am
I'm running a mallory 250, I sure like it.
I ran all the big holley and 140 carter machanical pumps before with no luck.
cheatham
cheatham
Post  Dave De March 26th 2016, 3:33 pm
Aeromotive A1000 pushing E85 and running 9.11 with 3100 pounds for 5 years.
Post  FalconEh March 26th 2016, 3:51 pm
Dave De wrote:Aeromotive A1000 pushing E85 and running 9.11 with 3100 pounds for 5 years.
Dave, it is time to put that street/strip monster on a diet...shave 120 lbs and put it in the 8's Very Happy That's one Bad MoFo street/strip car Exclamation
Post  Dave De March 26th 2016, 4:05 pm
I think I'm going after it with a few setup changes this spring.
Taking the heavy full 4" exhaust off for 70 pounds reduction. Add an air pan, chin spoiler, and block off the grill. I should know in 3 weeks.
Thanks for the compliments.
Post  Mark Miller March 26th 2016, 10:25 pm
D. Sea wrote:I'm still running Two Mallory comp 140 fuel pumps.  Both over 20 years old and they just won't quit.  Geo Rotor Designed like an oil pump so they will last "forever".  Key to keeping them alive is to keep your fuel clean with a good filter before the pumps.
X2,that's what i run and have had good luck with them.Plus you can buy rebuild kits for them from Summit Racing or Jegs.
Post  BigRigTech April 7th 2016, 8:30 am
I use an Edelbrock 160GPH electric fuel pump, so far so good. Complete 8AN fuel system from the tank to the bowls.
BigRigTech
BigRigTech
Post  gmsmkr April 7th 2016, 10:12 am
Been running A1000 for years with gas I'm fixing to see how it does with some m5
gmsmkr
gmsmkr
Post  maverick April 7th 2016, 1:36 pm
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^That oughta put it in the 8's. Cool ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Post  bbcoupe April 14th 2016, 6:11 am
Best bang for buck....
I used a Holley Blue with return style regulator running through 1/2 fuel lines to 1150 carb. 10.86 in 3800lb street car.
bbcoupe
https://www.youtube.com/user/coupe545
Post  biglucky April 14th 2016, 7:03 am
Holley blue has been in mine for years and been 5.70@120 mph.
biglucky
biglucky
Post  DaveMcLain April 14th 2016, 7:30 am
On my dyno I've been using two Holley black pumps for at least 10 years and they've always worked well. It is a simple system, a 5/8 fuel hose splits to the pumps which then feed into a single 5/8 that goes to a canister fuel filter that was scavenged from a Detroit Diesel at the junk yard(no joke). In that filter I have a Wix "any fuel" filter element. After that it goes up to the carburetor area where I have an aluminum fuel log with four fittings, two -6 and two -8 and then on the end of that log I have a return style regulator from BLP. The regulator has a small jet which allows a little fuel/air to bypass all the time even if the regulator is closed. Extra fuel returns back to the tank through a 3/8 hose. This is great because it allows the air to purge immediately which is handy when changing fuels or switching stuff around.
I think that having the bypass regulator setup really helps with these pumps because then they only build the pressure that's needed rather than run dead headed and against their internal regulator which is about 15psi. My pumps are pretty quiet and they don't get hot even after running steadily for hours.
I think too that it might be important and better to have a system that doesn't beat on the fuel too much and that having the fuel come through a regulator and suddenly go from high to low pressure might cause some light ends to flash, changing the fuel. I'm not sure that really happens but it could.
I run the pumps with two switches, one is a momentary "bump" switch that's used to fill the bowls and check for leaks. The other is the "run" switch that's a toggle on or off. The run switch is generally left on and the pumps are controlled using a 30 amp accessory relay and a Holley pressure switch that's wired so that when there is oil pressure the pumps turn on, no pressure they turn off, automatically. Very simple.
I just recently ran a big Ford than made 1029 horsepower on gasoline on this dyno with no problems what so ever, 7 psi from start to finish. Since there are no inertia effects I wonder how much power could be fed in a typical drag racing application with this same system?
Also, these pumps have been run with all grades of regular pump gas, E10, E85, racing gasolines and methanol without problems.
DaveMcLain
