Adaptor Mounts and BBF Trucks
That's all.
https://www.dropbox.com/s/7w38a4qjwuf8a8f/2016-03-22%2019.59.49.jpg?dl=0
https://www.dropbox.com/s/4s3bindbz2a6ojd/2016-03-22%2019.59.30.jpg?dl=0
https://www.dropbox.com/s/32xlh3uuqwv4zja/2016-03-22%2019.59.37.jpg?dl=0
supervel45- Posts : 4499
Re: Adaptor Mounts and BBF Trucks
They work fine on my end, has to wait a few seconds though. New solid mount being fabbed today, they do make for a good pattern,LoL.
Working for you because it is your dropbox account.. I get a permission error. might try uploading on Photobucket and sharing from there or check your sharing permissions to that folder on Dropbox.
Thanks for letting me know.
Check the links I added in the first post. Can't get them to imbed for some reason.
Last edited by supervel45 on March 26th 2016, 12:30 am; edited 2 times in total (Reason for editing : Pic Fail)
links are working now for me.. Broke it didn't Ya.
res0rli9- BBF CONTRIBUTOR
This is why I refuse to recommend those type of adapter mounts to anyone they do not have any type of torque limiting protection built in.
I can't recommend solid mounts for everyone because it causes driveline failure later on if not installed correctly. Poly mounts are more than enough for most. If you need more then it is time to change to motor plates.
If you run solids up front then the rest of your mounts should be solid as well.
SandHillsHillbilly wrote:This is why I refuse to recommend those type of adapter mounts to anyone they do not have any type of torque limiting protection built in.
You do have to be careful with mounts so you don't crack the trans case. I agree on the poly mounts and have run them before also. The Adaptor mounts gave no more problems after I strapped down the engine with a slight amount of play. Pissed me the FOff when they cost me a $400 dollar
4 row Modine though.
^^^^^^^Nice. We just boxed ours but that solid looks unbreakable.
» Towing topic - new trucks vs older trucks ratings opinions looking at new trucks
» 460 oil filter adpt
» spline adaptor
» Transmission adaptor
» OIL FILTER ADAPTOR FOR OIL COOLER
» spline adaptor
