Air Pan Ideas
Air Pan Ideas Empty Air Pan Ideas
Post  Dave De March 26th 2016, 7:24 pm
For early Mustang 1969 with a 5" cowl hood.
I am thinking about attaching an aluminum sheet with a large hole to the bottom of the hood and use the Moroso drop base on the dominator before the hood is attached. There are limitations on this but I dont know another method to make an air pan with this setup.
If those of you that have this type of hood and car could give me some ideas I would greatly appreciate it.
Air Pan Ideas Empty Re: Air Pan Ideas
Post  FalconEh March 26th 2016, 7:34 pm
Dave,
Most of the functional ones I have seen have an aluminum belly pan attached to the carb with a foam sealing around the outside, kinda like a GTO, GS 455 Ram Air setup but with a way bigger hole and a lot more foam.
Post  gt350hr March 26th 2016, 9:09 pm
Or a combination of both. Hood hinges cause the hole in the hood to be slightly oval shaped so foam around a Moroso base should solve any sealing issues.
gt350hr
Post  70FB March 27th 2016, 9:34 am
70 mustang. 4-3/4" cowl
Air Pan Ideas 033_zps52330fbb
Air Pan Ideas 037_zpsfd47a424
Part of the mock up. This is looking in from the windshield side. At cowl opening.
Air Pan Ideas 120_zpsf730f889
70FB
70FB
Post  Dave De March 27th 2016, 1:46 pm
70FB wrote:70 mustang. 4-3/4" cowl
This design looks like the ticket for me. Its simple and easy to make. My carb flange is a little higher but it should work well. I can trim the sides after the hood is fitted and use foam on the sides. Going back to an air cleaner for street use is easy as well.
Thanks for posting this.
Post  70FB March 28th 2016, 1:18 am
No problem. Instead of foam I used the c channel stuff from Mcmaster Carr.
Here ya go.
http://www.mcmaster.com/#rubber-bulb-seals/=11qasss
70FB
70FB
Post  70FB March 28th 2016, 1:21 am
Just have to know what height you will be at.
Then take a piece of yarn and tape to the back of cowl and observe it going down track. If it goes in towards the carb..... Your good.
I'd expect you will be fine.
Good luck!
70FB
70FB
