so i got and installed my SB front springs...
so i got and installed my SB front springs... Empty so i got and installed my SB front springs...
Post  63boxtop December 1st 2009, 10:35 pm
in the galaxie to help with weight transfer on the launch my bb w/ ac, convertable springs measured as follows
coil thickness ..3/4"
height 17"
width 5 3/8 "
the small block no a/c springs measured as follows
coli thickness 5/8"
height 18"
width 5 3/8 "
so i get them installed and the front seems to sit a bit higher which makes a little sense since the free height was 1" more, but i would of thought that the fron would sit lower since it has the 557 in it, does that make sense to you guys,
thanks
rick
63boxtop
so i got and installed my SB front springs... Empty Re: so i got and installed my SB front springs...
Post  the Coug December 1st 2009, 11:17 pm
let her sit a few days Rick it may settle in and lower....
Post  63boxtop December 1st 2009, 11:35 pm
iwas going to jump on thr front end a few times but knowing my luck my fat ass would break some fiberglass and i would really be pissed then Shocked
on to the rear now. i'll let you kno how it turns out randy
rick
63boxtop
Post  longroofracer December 6th 2009, 12:05 am
Like Randy said... they will most likely settle a bit after you drive it around some and cycle them. Just rolling it back and forth in the drive won't do anything to them. Get some good measurements from somewhere like the center of the crossmember for reference purposes before and after 50 or so miles.
longroofracer
longroofracer
