First Ford, first big block...
Evening fellas! I got my 63' Thunderbird a month ago and the previous owner dropped in a 429. It's had a heating problem from day one so I thought this would be a good place to learn more about my motor.
I originally thought I was going to flip the car but I'm digging it it so much I'm keeping her. Looking forward to wrenching this classic.
Be cool fellas!
Be cool fellas!
Cebu- Posts : 2
Re: First Ford, first big block...
Welcome aboard. I have heard the 1972 and up 429's ran hotter because of the retarded cam timing. I changed my timing chain to a 1968/71 model before I ran it, so I can't give first hand experience but, you may want to check into it.
supervel45- Posts : 4493
Check all the obvious things first...radiator blockage inside (rust, crud, etc)
Airflow through the radiator....adequate enough??...enough fan??
Hoses...particularly the bottom hose. Does it have a spring inside it to keep it from collapsing??...kinks??
Water pump....is the pump impeller still intact?? corroded??
Thermostat....is it functioning properly??...is it installed properly??
BBFTorino- Posts : 997
» New 57 Ford Project Should we go big block or small block? Pics added
» big block ford parts,and sb ford
» BIG BLOCK FORD 605
» Not a Big Block Ford but......
» 605'' big block ford
