Head gasket ?
whitefield
Head gasket ?
I have been over thinking and reading I guess !
I would like to know what the preferred head gasket for a 13.5 351w N/A would be or that you guys have had the best luck out of ? Thanks
whitefield- Posts : 2244
Re: Head gasket ?
whitefield wrote:I have been over thinking and reading I guess !
Other's may have differing opinions but with 13.5:1 in my Cleveland's NA I could run any Felpro gasket from the local NAPA with success, with the juice or a bad tune it will be different.
FalconEh- Posts : 1448
Re: Head gasket ?
We usually just use 1011-2 fel-pro or 8548pt2
whatbumper- Posts : 3024
Re: Head gasket ?
whatbumper wrote:We usually just use 1011-2 fel-pro
1011-2 is it any better than the 1011-1 ?
I have been using the 1011-1 , l didn't know if there was anything better or recommended .
Re: Head gasket ?
whitefield wrote:whatbumper wrote:We usually just use 1011-2 fel-pro
Don't know if there is any performance advantage but we've just had good luck with that one number.
Re: Head gasket ?
http://www.summitracing.com/parts/fpp-1011-2
I think that's kind of like the 1018 in the 460 world. I am going back with PT's myself and the 1018 where not that much more. They held up to a lot of spray but, did not have much compression. I'm with Falcon on the stock Felpro's, they worked for me. They say the 1011-2's go better with aluminum heads to keep corrosion down in the add also.
supervel45- Posts : 4494
Re: Head gasket ?
1011-1 has a thicker compression. .041
1011-2 has a thinner compression. .039
Both good we use 1011-2 also
gmsmkr- Posts : 1364
Re: Head gasket ?
A 1011-1 is a bit stronger and has a pre-flatened STEEL wire "O" ring under the metal cylinder bead overlay.
A 1011-2 is a bit thinner and has a pre-flatened COPPER wire "O" ring under the metal cylinder bead overlay.
A 1011-1 has the tendency to brinnell a groove in an aluminum head which is not all bad if you continue to use THAT gasket.
Re: Head gasket ?
We had good luck going back after being run one night of racing and re-torqueing them on our 14:1 Cleveland.
I don't remember the felpro number, but it was the standard parts house rebuild gaskets the blue ones.
Never lost one after we started doing that, even on the spray.
Re: Head gasket ?
IDT-572 wrote: We had good luck going back after being run one night of racing and re-torqueing them on our 14:1 Cleveland.
People are just to lazy to re-torque head bolts/studs on a high performance engine. After all, the gasket companies ads say you don't need to do it ... you bet.
Re: Head gasket ?
rmcomprandy wrote:IDT-572 wrote: We had good luck going back after being run one night of racing and re-torqueing them on our 14:1 Cleveland.
That so they can sale you some more and tell you it was your fault you installed them wrong.
Re: Head gasket ?
This is what kills me they want all this performance but don't want to do the up keep and maintenance on them
» Head Gasket ?
» Head Gasket ?
» head gasket
» Need head gaskets (Lem?)
» when to use an mls head gasket.
» Head Gasket ?
» head gasket
