Need head gaskets (Lem?)
For some (right now unimportant) reason I find my new bottom end has the pistons up .005" out of the bore. I have a 4.420 bore, a real comp ratio of 15.4 if the piston were flush and wishing a quench of at least .040, I need a different set of gaskets. Running racing gas and turning 6K. What do I want and where do I get them?
Thanks in advance...
Perry
Perry
hpwdboss1- Posts : 147
Re: Need head gaskets (Lem?)
Lem's a good soure and has a bunch of stuff in stock.
The FRPP gaskets are .041".....in stock
The Cometic we stock are .040"/.045"/.051"
What cyl. head do you have?
RE: need head gaskets
Running old iron D0VE-C heads.
Perry
Perry
Re Head gasket to Lem
I will do just that! I have just today got back to the keyboard with absence due to horrible flue. Will be contacting you or Shawn in very near future. Thanks for the help , again!
Perry
Perry
For Lem
Can Cometic gaskets be reused on a different block IF the block surface meets spec.(smooth)?
Lem Evans wrote:If the gaskets are in like new condition i'd think they'd work.
Thanks Lem
I have reused them with no issues, as stated make sure they are intact, I give um a cleaning and put a thin layer of coppercote..although its prolly not needed.
