Transmission fluid fill
Finally about ready to get the car drivable again after two years. How much oil does trans take for initial fill? and total ? C6 with 8" converter. Last new trans startup was 2008, can't remember the fluid amount -
glenevans- Posts : 315
Re: Transmission fluid fill
glenevans wrote:Finally about ready to get the car drivable again after two years. How much oil does trans take for initial fill? and total ? C6 with 8" converter. Last new trans startup was 2008, can't remember the fluid amount -
I always put
four quarts in for startup and then start dumping trans fluid in as soon as it fires. I would think about 10 quarts with the small converter.
supervel45- Posts : 4498
Thanks, that is very helpful
» 460- C4 bellhousing and pan fill C4 transmission
» New BTE C4 Transmission Aluminum Deep Pan Pan/Case fill
» best tranny fluid
» To Fill Or Not To Fill
» Are there two diffrent size front pumps for c4 pan fill and case fill ?
» best tranny fluid
