best tranny fluid
+9
kjett
badnotch
soupbean
johndickjr
13 posters
best tranny fluid
What is best tranny fluid to use for ford trannys? Redline..royal purple? B-m trick shift? Other
johndickjr- Posts : 896
Re: best tranny fluid
type-F
res0rli9- BBF CONTRIBUTOR
HyTran or from CaseIH or Hy Gard from John Deere
schmitty- Posts : 4538
best can depend on a lot of things
Best? or what do each of us run? LOL
We run hygard low viscosity in race cars no matter the trans. (I don't add anything for color because its easy to see if the stick is wet or dry IMO.)
AMSOIL ATF in all other vehicles.
whatbumper- Posts : 3024
Amsoil here
soupbean- Posts : 637
How well does hyguard do agsinst heat
You're in Ag country. Ask any farmer what their tractors go through.johndickjr wrote:How well does hyguard do agsinst heat
It is made to withstand higher heats than regular ATF. For what you do it will last as long as you are comfortable.
I use what Frank Merkl told me, plain old red Type F
kjett- Posts : 1169
When I picked up my pg from Cook Racing Transmissions in Cowpen SC he told me to run the Castrol Blue Hyd. ISO 46 part # 40247 he said that is all they run in theirs and it runs 10 to 15 degree cooler than the others does. I haven't run it yet but it will go in it when I put the trans in.
Same here.kjett wrote:I use what Frank Merkl told me, plain old red Type F
crittersf1- Posts : 521
Amsoil compressor oil 20wr
Ace
Ace
powerstrokeace- Posts : 1496
We run Synergyn, but i also tell my trans customers to run Mobil 1 OR ATI super F synthetic
steven gregoire- Posts : 68
transmission fluid
What type filters is everyone is using with the differ type of fluid. Can a stock filter be use Thank
67aj- Posts : 12
» How often to change ATF on a street car?
» how many Qts of tranny fluid in the powerglide?
» Best C-6 Fluid?
» C6 fluid help please
» trans fluid
» Best C-6 Fluid?
» trans fluid
