Best C-6 Fluid?
in4x4guy
mac460
Tore
Best C-6 Fluid?
Has anyone used the Hy-Gard fluid in a C-6? How did it work?
Tore
Tore
Tore- Posts : 865
Re: Best C-6 Fluid?
maybe Frank will chime in here ........
Re: Best C-6 Fluid?
frank will tell you good old type-f
mac460- Posts : 61
Re: Best C-6 Fluid?
ditto on franks reply it's allways the same type f don't was your money on expensive fluids!
in4x4guy- Posts : 3
Re: Best C-6 Fluid?
If you need to "snug" the converter up a tad the hygard will in that respect. Overall its a good fluid, unless the converter is already too "snug".
Re: Best C-6 Fluid?
richter69 wrote:If you need to "snug" the converter up a tad the hygard will in that respect. Overall its a good fluid, unless the converter is already too "snug".
Is it okay to mix the Hygard with Type F, maybe 50/50... or is there no benefit to doing so?
longroofracer- Posts : 250
Re: Best C-6 Fluid?
you guy's experiment and let me know how it works , I watch the kid go round after round and the C6 lives long after after the 2speeds die , sat nite at the track I generally hold a "Glide overhaul course" for whiskey!!!
Frank Merkl- Posts : 1524
Re: Best C-6 Fluid?
I started using Hy-Guard it this year and as of last weekend 256 passes. Tightened stall 200 and helped with shift flare I like it. Seems to handle heat better late rounds.
BIGDOG466- Posts : 265
Re: Best C-6 Fluid?
F for me in the small block with a c4 and the big block car with a c6 seems to work fine.
nuclearcobra- BBF CONTRIBUTOR
