Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild Empty Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild
Post  supervel45 April 25th 2016, 3:19 am
http://www.ebay.com/itm/222064928544?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The Beginning.
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild Empty Really Getting Into It
Post  supervel45 April 25th 2016, 3:28 am
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild TXxIxAAb7PnoBLuJKFagbLbQfs1ZgkjeTdYOIrzcwNY?size=1024x768&size_mode=3
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild UX1QhBHfiUgeqkCY7D-EzPWIlIHyS33pI55FK5cyZRs?size=1024x768&size_mode=3
Kickdown Lever still frozen to throttle shaft by saltwater rust likely at this point. Soaked in gasoline diesel and compressor oil heated and re-soaked for two weeks to no avail. If you want to know how I finally got it to break free all you have do do is ask. After messing with this stuff for over 30 years on many frozen shafts in the HVAC Industry and elsewhere I wish I had know much sooner. The Old Timers must have been holding back a trick because surely a few knew it. It's so simple it is stupid, and is quick, easy and readily available.
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild 9S8kIIpx1eJSWTQAGuMbwHiYVos20MCGrIxDaXqDXHE?size=1024x768&size_mode=3
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild Empty Re: Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild
Post  supervel45 April 25th 2016, 3:33 am
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild IT31onXE8mKmgXUEy4YT_MKoxcVuxmL1n7HLBIjOciw?size=1024x768&size_mode=3
Put a very heavy a very heavy coating of grease over the base plate gasket before you paint if you choose to ( paint it ) after bead blasting and Acid Etching. Wash gasket in solvent/gasoline and over spray comes right off.
Post  supervel45 April 25th 2016, 3:36 am
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild URLe9hzJ0BYFrAqELMg3RRkU4C46BYUAf0A8aNzVnMQ?size=1024x768&size_mode=3
Sand base plate on glass to check trueness of mounting flange. This one had a couple of high spots on the corners as shown in picture and I just knocked them down. You can go further and sand the base clear across if you choose but it is not necessary and very time consuming and I was kind of in a hurry to meet a deadline. I may go back and do it anyway just for looks.
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild JqIPF_fd5E7KxO-jLStrmOX1iyXhkBM09gkcDFap2Sk?size=1024x768&size_mode=3
I had painted the ends of the throttle shafts before they went in the Acid Bath. Surprisingly the paint held up. VHT makes some good stuff and the Dark Blue Anodize not pictured here is my favorite. 429 is going to get a coat of it now that I have seen what it looks like on Aluminum Valve Covers we Did.
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild QxuOYti6eKR9CPyAhFHRaF4AOm5a_fqbZWpgVXrSAhA?size=1024x768&size_mode=3
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild O93UehF92fupch45fCJDGxGs9_7Mo2Wy6iF9-oIUAgo?size=1024x768&size_mode=3
Post  supervel45 April 25th 2016, 3:40 am
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild WUn-yOzv-Yzx5RI_IWcTcDu49WWeBjt-_B66F0LkNAE?size=1024x768&size_mode=3
All my photos are not down loaded yet. Some guys around here may know whats in the can and what it is used for? If I post the next picture without the rest it will mess up the sequence and spoil the end.
Post  supervel45 April 25th 2016, 3:43 am
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild _mWFcUKIH2-Z5C71upzx-Q_kLx5RdqgleLDTSg7sU_0?size=1024x768&size_mode=3
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild _SVauIazTKAeOmxhT-BPxeChnLLEdSXKhihcrwlB4iU?size=1024x768&size_mode=3
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild QR37uDGHggXci-ENLi0Kz07wXKBPsE5gymYjNVk4_70?size=1024x768&size_mode=3
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild Kg9iEqEu6hUARXXqwPlsmsVUlwnnuaKFbbKG6EdCIvw?size=1024x768&size_mode=3
Post  supervel45 April 25th 2016, 4:37 am
4 or 5 things left to do and she will be compete.
3 Of the main items
1. Locate or fab lever for primary bowl vent valve lever.
2. Drill primary throttle shaft to install locking screw from where factory stake was removed to aid in restoration. May remove shaft again and install in lathe to get a perfect center (not loooking forward to that.}
3. Remove base plate install on drill press at correct angle and drill out broken throttle position set screw and  re-tap hole.  Don't buy used Marine Carburetors with the throttle shafts stuck especially with a Ford A/T transmission kick down lever and save yourself tons of grief. If it was  not a very hard to locate carb., I would not have done it. On the Up Side  I learned a Great Deal and really enjoyed the challenge. I also suspect if I sell it I will do very well.
http://www.ebay.com/itm/172178289312?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
^^^^^ This Carburetor Closed at 385.00 last week reserve not met.
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild Empty Base Plate Almost Complete
Post  supervel45 April 25th 2016, 4:45 am
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild D7YDG4wXO-Qqd2c3-Z08BcjBgm5TvtksMoV1UdsXHBY?size=1024x768&size_mode=3
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild AH3pORmpPPeee3vjni3PpuVM8Il52-zrR1b79L826TU?size=1024x768&size_mode=3
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild Empty The Start of The Build
Post  supervel45 April 25th 2016, 5:06 am
Not the same carb. but, what it looks like in pieces. The only part I have never taken out of a Holley are the Emullison (spelling) Tubes in the metering blocks but, that is my next project when the new cap plugs come in. Never had to but, something I have always wanted to. It makes for a total and complete restoration. I am going to move up to the big dollar stuff hopefully like Shelby and GM original equipment Carbs. after I get my plating kit.
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild YTrm_jJ6LNNOj29J50S8tnXiOL-RpWFGF1tErH33UJw?size=1024x768&size_mode=3
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild WIN1MmDPGuGMeN4C1YEBZfHArENqGgwtXp3aJ-Q7vuA?size=1024x768&size_mode=3
Just a few of my Holley Parts.
Post  supervel45 April 26th 2016, 11:35 pm
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild 2016_04_25_01_34_41
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild SQkKyA0WiA5OrbOVHaEbEtwRS5zDZoXququLYSa4HEg?size=1024x768&size_mode=39
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild FqD7Tl_aX-J1fVNK9WOgTnPi2tYB8Cd6gp37oXL_Eu8?size=1024x768&size_mode=3
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild RGEwyRGbVFfEb_cheD_DrJnD95kLWjxROOULyKsu6D4?size=1024x768&size_mode=3
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild Empty Photo,Org. Having Problems Tonight Hope You Can See Drop Box Pics's
Post  supervel45 April 26th 2016, 11:59 pm
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild Yp8PqC7ASuHr41KXmmBnAdFf2_90XlFXHRvjzK3TFcc?size=1024x768&size_mode=3
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild HHO9tRhPSgBamCZJcazYrKZpvYVcEmCecPL0lZzGMBk?size=1024x768&size_mode=3
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild 6a6sFwZ07TEcpw9HOYBflnDum3VioZctMLz4DJ2cISA?size=1024x768&size_mode=3
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild EHgm7IDQd_V4nA19jcR4HBXgdgOdHNZz1yWtrD1-9dU?size=1024x768&size_mode=3
You Would be Surprized at how much trash comes out in the strainer after the Acid Dip.
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild 4PCX-Ksh2IziRKxTHBsxWUW6kWdU6Pv8dR5KbiQp3uk?size=1024x768&size_mode=3
Hot Sauce Bottle is for Cold Blue to save from contaminating so to save from contaminating too much chemical. Need an even smaller tube like a pipe but, I was in a hurry and grabbed the first thing handy. Don't drink to much at one time but, this stuff was about like V8 and pretty whimpy.
Post  supervel45 April 27th 2016, 12:04 am
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild YHBOV5qK7gROuuXfd_PnKfqtAQ8TR0SUgXK0yDnKUio?size=1024x768&size_mode=3
Got to pay for these bad boys somehow.
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild Cdo2C2q4ho3A75tqxV-i-uudbraaARcCjvUEJrxZb0E?size=1024x768&size_mode=3
A few of the personal stock and one 750DP fixing to be sexed up and may go to the Auction Block.
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild LjhgUMfhC8Ix9l_9ZhgyPjWL6ym3FeP0nDOAC4GnHag?size=1024x768&size_mode=3
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild E2TakEk2SmJm5Sk3SnfrlIeW90NXZXEjDrjaeDPI-NY?size=1024x768&size_mode=3
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild V13TrLa1PIwfYLsADTBS1UFTXriyBR_hcC3oo8Afw-A?size=1024x768&size_mode=3
Post  supervel45 April 27th 2016, 12:09 am
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild -9JP-mFBVdgP-32hdcIlkkTYapdR_tMMscGnomSOreI?size=1024x768&size_mode=3
The nice thing about Carburetor work is it does not take much space, they are not heavy, greasy, or expensive, and don't take many special tools. Once you wash the solvent off with water and if your Old Lady is Cool you can bring them inside and work in the A/C and even at your computer desk if you want to, LoL. Cut many new screw slots that way and posted while doing it. About the only thing I like doing on a Hot Rod anymore is a Big Holley Double Pumper.
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild HsjIk7UygC8hsSqBuFikjnRdTUo2D9MoNcXGgGJfMBg?size=1024x768&size_mode=3
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild Zi9iDg7qVGhBe5mLC72xDmrc2jVln4BK1a-t82dh4Co?size=1024x768&size_mode=3
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild NLbdqgF7vuLXdH8uNX6ywtTn04bFDS0XGbWmNWxV_po?size=1024x768&size_mode=3
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild UHWf7s0d3sBuonE6wWenma-yb0gya5yCyXooXoXqcn4?size=1024x768&size_mode=3
Post  supervel45 April 27th 2016, 12:52 am
Getting a refill of 100% Argon and the throttle shaft will be Tig Welded back on. Will post pictures of the want to be Welder's work if it comes out good, which I am sure it will, it better damn well be after all this but, I can't fire him like UPS, LoL, you know who I am talking about Mr.R. LoL if your up and reading this.
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild DnAkGoHRNlw2cgYpZdtVfs-TbsFrl-veYnhA7nZUCC0?size=1024x768&size_mode=3
This One is for Ronald, tell him thanks for his Patience.
Holley 650cfm DP with Ford A/T Lever Total Tear Down and Rebuild DhVIFmnU4uPn2FrsWHmm5yk3qbTF8XL3zBXxkNNQWOo?size=1024x768&size_mode=3
Post  jeffgfg April 27th 2016, 9:27 am
Yeah still nothing when I click on little boxes...............
jeffgfg
Post  supervel45 April 27th 2016, 9:46 am
jeffgfg wrote:Yeah still nothing when I click on little boxes...............
WoW Sorry about that. The PostImg.Org place seemed to work but their web site has a note saying they are having problems right now. When they get it fixed I will link the pictures from there. Thanks for letting me know.
https://www.dropbox.com/s/bqo7ahg2h2v5ec0/2016-04-25%2013.15.50.jpg?dl=0
You can click this link if you want to see a pic until I/they get the image deal sorted out.
