Wide cam bearings, --- Lem?
Do you sell the wide cam bearing sets for a stock block.
hpwdboss1- Posts : 147
Wide cam bearings
Thanks Lem. Will call
Re: Wide cam bearings, --- Lem?
Pardon my lack of knowledge on this subject.
One time about 25 years ago a fairly reputable engine builder in Fargo told me that in his opinion one of the limiting factors for a 385 series Ford engine was the cam bearings being too narrow, and he showed me a block with needle bearings, saying that was the fix if you wanted to run a solid roller cam with high valve spring pressure.
Is that true?
Craig
Is that true?
Craig
Babbit Bearings- Posts : 19
» Anyone using this, C6 Low Drag Gear Set with bearings, wide ratio planet gear sets?
» This 4 wide stuff sucks
» Wide Ratio Kit
» wide open hesitation???
» Wide 5 wheels
» Wide Ratio Kit
» Wide 5 wheels
