Cam recommendations seem to light to me? What am I missing.
JBR-3
paperman
I sent a inquiry for a camshaft to a couple grinders. I filled in the sheets with all the info. Basics are 4.5 stroke, 6.7 rod, 30 over, A429 heads cleaned up, Icon 10:1 pistons. F350, 4x4 C6 42" rubber, 5.13 in both ends. Victor intake, Domy carb, 2.125-4" headers.
They came back with what looks like a very soft cams. There are 4 different recommendations, here are 2 of them:
Duration @ .050 = 245/250
Lift = .576/.571
Duration @ .050 (Int/Exh): 233/241
Gross Valve Lift (Int/Exh): .564/.582
This seems to be fairly small for 545 inches. My last 466 used the C460 cam from FMS and I really liked it. I want to stay hydraulic flat as this is driven a fair amount.
Do these seem inline with what I am asking for or are they out in left field? I was expecting more in the mid .600's.
Lift = .576/.571
paperman- Posts : 88
Re: Cam recommendations seem to light to me? What am I missing.
Last edited by JBR-3 on February 22nd 2020, 2:39 am; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
Kinda, most run the low side of the Tcase at a 2.69:1 reduction before it hits the diffs.
I would say they are inline for your rig. You don't want to loose all your low end torque and also the A429 heads might not like as much cam as say P51's and larger heads would.
supervel45- Posts : 4499
paperman wrote:I sent a inquiry for a camshaft to a couple grinders. I filled in the sheets with all the info. Basics are 4.5 stroke, 6.7 rod, 30 over, A429 heads cleaned up, Icon 10:1 pistons. F350, 4x4 C6 42" rubber, 5.13 in both ends. Victor intake, Domy carb, 2.125-4" headers.
Lift = .576/.571
Valve lift IS a bit soft for those heads; first cam is close on duration ... maybe 3 or 4 more degrees of exhaust duration.
Your collectors are to big unless they are REALLY long.
The collectors proper are only 8" or so, but it is connected straight to a 4' length of 4" pipe with 2-45deg offsets midway.
You did not mention torque converter stall speed. It has a lot of bearing on cam choices also.
Dont own a converter for this yet. Trying to get the engine together and see how it feels. My plan was trying to keep stall as low as possible to keep the heat down. With the thick stuff we play in the load on the drive train is huge. In low gear, low range and 5.13 getting RPM's up should not be an issue. I have a giant cooler but we dont run 10 seconds at a time, more 10 minutes.
supervel45 wrote:I would say they are inline for your rig. You don't want to loose all your low end torque and also the A429 heads might not like as much cam as say P51's and larger heads would.
I am running .708 .712 on my a429 heads but it is a solid lift roller but he running a hydraulic flat tappet so that will limit his lift
What do you want max HP rpm to be?
Straubtech- Posts : 293
6000ish. I don't care to spin it to the moon and keep it there as RPM's cost money and maintenance. Not looking for a dyno killer, this is a big play truck that we take out on the weekends to enjoy being outside.
Ballpark.....
.620/.600
248/260
107
.620/.600
248/260
107
I found a Howards in stock, I needed a cam and this is what I settled on. Ill likely look for a better grind in the fall when it comes back out.
241491-10
0.614 int./0.635 exh
232 int./238 exh
110
Engine is together, waiting on new damper spacer as the old one magically walked out of the shop somehow Hope to install and break in next weekend, then get to enjoy putting the valve springs back together in the truck
241491-10
232 int./238 exh
110
paperman wrote:I found a Howards in stock, I needed a cam and this is what I settled on. Ill likely look for a better grind in the fall when it comes back out.
241491-10
232 int./238 exh
110
I'd advance that thing as much as you can, with that much piston speed in here at low rpm and now port velocity she is going to "hunt" for air.
» Anything I'm missing?
» engine missing solution
» 460 Missing
» A429 missing accessory bolt hole
» Am I missing .........
» 460 Missing
