Finally in the 4s
+8
99zx9r
Moodyblues
bigblock t-bird
70FB
chuck
12 posters
Finally in the 4s Empty Finally in the 4s
Post  chuck May 11th 2016, 10:41 pm
Finally in the 4s 20160417_015712_zpsfjmbswor
Pay no mind to the reaction, car stumbled going on 2 step. Not bad for 3200lbs on stock suspension.
chuck
Finally in the 4s Empty Re: Finally in the 4s
Post  Mike R May 11th 2016, 11:13 pm
cheers cheers cheers
Post  70FB May 12th 2016, 8:29 am
Nice. I'm hoping to break into the 5's this week. Congrats man. cheers
70FB
70FB
Post  bigblock t-bird May 12th 2016, 9:11 am
Very Happy Very Happy Way to go.
bigblock t-bird
Post  Moodyblues May 12th 2016, 3:02 pm
Congrats that is an accomplishment
Moodyblues
Moodyblues
http://www.russhoodinsurance.com
Post  bruno May 12th 2016, 3:07 pm
very nice , cant wait to be back in the 6's Very Happy
http://WWW.CKRME.COM
Post  chuck May 12th 2016, 7:29 pm
Thanks, finally got the front to stay down, after 2 bumpers, 1 set of headers, and oil pan. I think we had enough MPH for an 5.80 pass? This was with a sledge hammer plate with 78 jets, will go to an 84 jet next. The car would benefit from a 1.58 gear set, the 1.80 is pretty violent with the 3.89 rear gear.
chuck
Post  FalconEh May 12th 2016, 8:21 pm
cheers Well Done ! Cool ...video? Very Happy
Post  99zx9r May 12th 2016, 9:27 pm
Congrats...that's moving!
99zx9r
99zx9r
Post  whatbumper May 12th 2016, 9:54 pm
With the 84's,  you should be able to knock that front split down 8-10 numbers so it should fly. By looking at your backsplit, you have enough power now to run 84-85 range pretty easily.
Congrats! !
Post  Hardy May 13th 2016, 12:11 am
whats the setup? Engine combo?
Hardy
Post  chuck May 13th 2016, 10:29 am
whatbumper wrote:With the 84's,  you should be able to knock that front split down 8-10 numbers so it should fly.  By looking at your backsplit, you have enough power now to run 84-85 range pretty easily.
Congrats! !
you think a 1.58 gear set will get my 60ft down?
chuck
Post  chuck May 13th 2016, 10:31 am
Hardy wrote:whats the setup?  Engine combo?
A headed 598, glide, stock susp fox body. 3200lbs
chuck
Post  whatbumper May 13th 2016, 1:10 pm
Congrats! !
Yes, due to the fact that you will be able to leave on more power and it not be so violent on the starting line. It will also give you the option of changing rear gears to make the motor happier in high gear.
Post  richter69 May 13th 2016, 1:12 pm
Same
Post  chuck May 13th 2016, 4:35 pm
richter69 wrote:Same
From experience?
chuck
Post  richter69 May 13th 2016, 5:31 pm
From experience?
Its how all the fast guys are set up, i already have a 1.58 gearset sitting in the floor....
Post  whatbumper May 13th 2016, 8:37 pm
From experience?
Yes, and then the next step us to get rid of the 3.89 gears.
Post  chuck May 15th 2016, 11:02 pm
whatbumper wrote:
From experience?
I have a another rear chunk with 3.50 gear, for the time being do you think they would be better than the 3.89? Tranny has 1.80.
chuck
Post  NITROUS FORD May 16th 2016, 5:01 pm
that's what I have in mine chuck (3.55) with 1.80 in my pg! hope mine work out to, if not I have some 3.27 for the induction solution fogger! Very Happy
NITROUS FORD
Post  whatbumper May 17th 2016, 12:08 am
I'd go the other way. Make high gear happy and your motor will live better.
Post  richter69 May 17th 2016, 12:15 am
whatbumper wrote:I'd go the other way.   Make high gear happy and your motor will live better.
Same
