Good C6 builder in NoVA
Anyone have a good trans builder in VA/MD/NC/western WV they can recommend? Tired of the typical "you can't build a c6 to hold any power" and the other "just put a glide or turbo 400 in it" routines. I'm looking for someone that can fix my c6 once and for all and make it live more than 1/2 dozen passes in my mud truck!
kjett- Posts : 1169
Re: Good C6 builder in NoVA
what you breaking ? you have one of my vb's don't you?
Frank Merkl- Posts : 1524
Frank,
Yes, I'm running one of your TB bodies. That part works fine, I just keep burning up the clutches or the band. Last year the thing was out several times for either direct drum clutches or band. Can't find a shop that will set up the clearances to what you recommend on the paperwork with the vb, so reluctantly, I let a friend that supposedly knew how to build transmissions go through it and I had to pull it apart 3 times last year as a result. Thought it was all good after a sucessful event last fall and 1st time out this year it eats itself again. I'm just looking for someone to put the main part of the trans together with the correct clearances you recommend that you have tested and know works especially with your vb. I'm not a trans guy, but fear I may have to become one to make sure everything gets done correctly.
kjett- Posts : 1169
Franks setup just works . Can't understand why anyone wouldn't follow it The servo, if a Sonnax has been machined or
checked ? And when checked use trans oil not assembly lube . If that was hanging one wouldn't help.
Gregaust- Posts : 625
I know Frank's setup works, there are too many on here and the other site running his setup to his spec's with great results. Problem is you know how every engine builder or trans shop is, they know what's best and everyone else is a hack and is just guessing. After having a nice chat with Frank yesterday, I decided to just order all new clutches and will pull the thing apart and do it myself. I'm done with the local guys!
kjett- Posts : 1169
Good decision . There is enough of us here to help you out, Sing out if you need a hand
kjett wrote:I know Frank's setup works, there are too many on here and the other site running his setup to his spec's with great results. Problem is you know how every engine builder or trans shop is, they know what's best and everyone else is a hack and is just guessing. After having a nice chat with Frank yesterday, I decided to just order all new clutches and will pull the thing apart and do it myself. I'm done with the local guys!
I think that was a wise choice also.
supervel45- Posts : 4498
Let me know if I can come up and give you a hand with it
crittersf1- Posts : 521
crittersf1 wrote:Let me know if I can come up and give you a hand with it
you know you and Lulu are ALWAYs welcome if you want to come up and get away!
kjett- Posts : 1169
» C6 builder in Michigan
» BBF in a Nova
» looking at an EFI builder
» Dad's Nova is for sale
» Tired of hearing about the "FARM TRUCK".....on street outlaws...
» BBF in a Nova
