Broken intake bolt 93 5.0l
+7
crittersf1
11 posters
Working on my 93 LX 5.0l. It has always used a little coolant so I finally decided to take the intake off and have a look. I broke the passenger rear bolt off. The other rear corner bolt was all carboned up but I managed to get it out. There is not enough sticking up to get vice grips on. I heated the bolt and soaked it with PB blaster several times. THen I welded a bolt on top but it still won't budge. I soaked it some more and I am going to let it set till morning. If it won't budge I was thinking of heating it up again. At some point I will probably have to drill it out but that is going to be a bugger against the firewall.
Does anyone have any better ideas?
While you are here... Is it normal to have this much oil in the port? I assume it is from the egr. The car has 92k miles. It doesn't smoke or use oil.
jasonf- BBF CONTRIBUTOR
Re: Broken intake bolt 93 5.0l
You have the bolt welded already, try heating it with a torch and use a candle to hold against it, the wax will melt and run down the threads and act as a lubricant when it cools, I have done this many times on exhaust manifolds with success to the point I keep a candle in the tool box for this purpose.
FalconEh- Posts : 1448
Looks like you found where the coolant was going
crittersf1- Posts : 521
I let it sit overnight and it came right out in the morning. The PBS Blaster worked it's magic.
jasonf wrote:.......The PBS Blaster worked it's magic.
PB Blaster is some damn useful stuff. It surprised me how fast it will knock down corrosion on battery posts.
DILLIGASDAVE- Posts : 2262
Glad it worked out for you.
If any of you guys are looking for the best penetrating lube for jobs like this...try a 50/50 mix of acetone and ATF.
maverick- BBF CONTRIBUTOR
Use it all the time!maverick wrote:Glad it worked out for you.
crittersf1 wrote:Use it all the time!maverick wrote:Glad it worked out for you.
I recently tried some stuff called "Kroil" with pine oil in it. Seems to work OK for loosening corroded bolt threads.
I haven't been able to find Kroil for years. My dad had that stuff for years growing up and worked like a champ
jbozzelle- Posts : 3705
Lol.. my buddy's dad used to boast about Kroil 25 years ago.. we thought he was brewing it up in the basement
Hey, guy's - just did a little online search for "Kroil", it's available from Amazon as well as others. Amazon offers an 8 ounce can for 15.95 (best price I found in my brief search). So this miracle rust busting concoction is still available, hope that was helpful.
Wayne (SAWDOFF) Pearce
Wayne Pearce- Posts : 658
I use it and keep it on hand. Good stuff. You can order it directly from the Kroil people too.
tornado- Posts : 25
I've been using Kroil on my guns for yrs.
res0rli9- BBF CONTRIBUTOR
» broken bolt
» 01 V-10 broken exhaust manifold bolt?????
» A460 intake bolt kit
» Victor 4500 intake for sell , no stripped bolt holes $225.00
» Best 4-Bolt caps/DOVE-A 2 Bolt
