broken bolt
342g
broken bolt
Has anyone ever had a bolt in the jomar stud girdle break, my car got a vibration in it, and backfired a little, I shut it down, took it to the pit, and pulled the valve covers off, all I found was a broken bolt in the girdle, has this ever happened, and would it cause the trouble I mentioned?
Bruno move this up, I messed up, should be in engine tech.
342g- BBF CONTRIBUTOR
Re: broken bolt
Re: broken bolt
improper torque? what else is broke?
Re: broken bolt
broke bolt should'nt cause a miss,IMO.but a miss could cause a broke bolt!
Re: broken bolt
Harold,that reminds me did'nt something like some sorta miss happen last season and you never really knew what ever caused it.
Re: broken bolt
bbf-falcon wrote:Harold,that reminds me did'nt something like some sorta miss happen last season and you never really knew what ever caused it.
Hell I don't remember, but I can't figure the problem, unless the washer got in the valve spring or something.
Re: broken bolt
hell put another bolt in it and run it! it'll show up later if it's a problem.
Re: broken bolt
I had one break on a Probe girdle. But ,it broke when I was tightening it. I think everybody wants to get a little torque happy on the poor little 5/16 bolt.Good thing you caught it before broke some stuff,better take a close look at your valve springs?
56Tbird- BBF CONTRIBUTOR
Re: broken bolt
they only go like 22-24 ftlbs.
Re: broken bolt
cool40 wrote:hell put another bolt in it and run it! it'll show up later if it's a problem.
I ordered 16 new grade 8 bolts, and 16 new washers, the old ones are grade 5, so overkill can't hurt, I checked all the rockers, push rods, and springs, so I going to put her back together, I think the bolt might have been broke for a while, the distributor was the culprit, I sent it back to msd for a complete rebuild.
Re: broken bolt
my old Jomar had the gold grade 8 bolts, I noticed the new girdle for the P51's had the chrome bolts.....I didnt look at the grade............dont matter I'm under the valve covers after every race anyway............
Re: broken bolt
last msd distributor i ran was a "new" POS. i made a new bushing for it and put a few holes in it for a little extra oil and it was ok.it did'nt have 500 miles on it when it took a dump.342g wrote:cool40 wrote:hell put another bolt in it and run it! it'll show up later if it's a problem.
Re: broken bolt
Hope the new bolts and Dizzy gets ya fixed up Harold
Re: broken bolt
bbf-falcon wrote:Hope the new bolts and Dizzy gets ya fixed up Harold
The new bolts are just for peace of mind.
Re: broken bolt
342g wrote:bbf-falcon wrote:Hope the new bolts and Dizzy gets ya fixed up Harold
Like a high quality condom?
Curt- Posts : 2791
Re: broken bolt
Curt wrote:342g wrote:bbf-falcon wrote:Hope the new bolts and Dizzy gets ya fixed up Harold
Exactly, , trojans all the way.
» Broken intake bolt 93 5.0l
» cam pin broken
» Best 4-Bolt caps/DOVE-A 2 Bolt
» 4 bolt main conversion? Or 2 bolt main stud girdle?
» Rod bolt and cam bolt torque?
» cam pin broken
