cam pin broken
Larry Williams
cam pin broken Empty cam pin broken
Post  Larry Williams August 16th 2011, 2:56 pm
the cam pin in my sbf has sheared off. is it possible to remove it and how? Its a comp cam solid roller with a blind hole.
Larry Williams
Larry Williams
cam pin broken Empty Re: cam pin broken
Post  rmcomprandy August 16th 2011, 3:30 pm
Drill & tap the remaining pin to a 10-32 and use a slide hammer.
Post  whitefield August 16th 2011, 3:54 pm
Larry Williams wrote:the cam pin in my sbf has sheared off. is it possible to remove it and how? Its a comp cam solid roller with a blind hole.
. Talk to Red Jones or 61coon. I had one to shear off in my cam and ole Red got it out for me.
whitefield
whitefield
Post  IDT-572 August 16th 2011, 4:35 pm
rmcomprandy wrote:Drill & tap the remaining pin to a 10-32 and use a slide hammer.
x2 and It would be a good idea to double pin it and if you buy a new cam ask for it to have a .4375 bolt too.
Post  Lem Evans August 16th 2011, 7:12 pm
Larry, when you get that thing out......I'd be glad to mail you a Danny Bee 4340 pin.
Post  Larry Williams August 16th 2011, 8:03 pm
is it a "soft " pin or a hardened one. will I need a special drill bit?
Larry Williams
Larry Williams
Post  Larry Williams August 16th 2011, 8:04 pm
Lem Evans wrote:Larry, when you get that thing out......I'd be glad to mail you a Danny Bee 4340 pin.
should I use 2 pins Lem?
Larry Williams
Larry Williams
Post  cool40 August 16th 2011, 10:40 pm
it should be soft if it's like all the pins i've saw.2 pins would be a real good idea too.i guess you have some bent valves? Crying or Very sad
Post  Larry Williams August 17th 2011, 8:02 am
sure do lots of them
Larry Williams
Larry Williams
Post  Larry Williams August 17th 2011, 6:27 pm
well I got the broken piece out. a lot easier than I thought it would be. it was a soft pin. center drilled it and out it came. no slide hammer needed.
Larry Williams
Larry Williams
Post  Lem Evans August 17th 2011, 6:28 pm
Yes...if it is a roller cam.
Post  Larry Williams August 17th 2011, 6:44 pm
can you send me 2 pins please. do you still have my payment information or should I call
Larry Williams
Larry Williams
Post  Lem Evans August 17th 2011, 7:26 pm
I'll call or you call me.
Post  Larry Williams August 26th 2011, 12:21 pm
Lem Evans wrote:I'll call or you call me.
Many thanks Lem The pins have arrived
Larry Williams
Larry Williams
